Ambo II
Vetter
Hey guys, cool sight!
Been looking through the threads and finding a lot of great information.
I have converted a few E350 vans to 4x4 in the past, I started my first Ambulance rebuild and conversion to 4x4 back in 2003, it was a 1989 E350 7.3 diesel, drove the heck out of this vehicle and raised two kids in it, but the Michigan winters have finally taken a toll on the front body and it has rusted beyond repair, plus the trans finally gave out.
So I have been in search for a replacement, just picked up a 1990 E350 7.3 diesel, I like these older body styles, plus this one was a "Dive Rescue" unit which was retired as a Ambulance in 1996 with 124,000 miles, I just picked it up with 128,000 miles, hadn't been used much and it was stored inside. The body is in great shape, very little rust, which is hard to find in Michigan.
My plan is to use a divorced NP205 transfer case behind the 2wd E4OD, the same I used for the other ambo, then install a Dana 50 TTB front. I have been collecting TTB's for a few years now, I actually did a "cut and turn" on one for a buggy I built, and it worked so well I plan on doing the same thing to Ambo II.
I have attached a pic of Ambo I, and the "Junk Buggy" I built with a TTB (It looks much better now finished). Don't have any pics of Ambo II yet.
The reason I'm posting this, is to ask a question about removing the wall between the front cab and box, these older Ambulances don't have much leg room, so I want to remove the wall behind the driver seat so I can move it rearward a few inches. I have noticed on some of these builds, it looks like some folks have removed this wall, just courious if removing the center supports that make up the walk thru door frame causes any structural issues, or does the front cab have enough strength to support the box also?
Vetter
Thanks for the reply back Bikersmurf.
I went ahead and cut out the wall behind the driver seat, made a huge difference for leg room. I plan on keeping the cabinets and wall behind the passenger seat, I think the way it is setup would work out good for my plans.
I have attached a pic of Ambo II, already removed the red lights, and replaced the emergency light bar with a LED, works great for trails. Going to add clear lenses on the front red lights just to see how that works? Need to put a new torque converter in it next weekend, I couldn't get it to lock up and that will fry a E4OD very quickly(that's what happened to Ambo I).
Then will start converting to 4WD.
Bikersmurf
I can see why you needed to cut that out... I've got about 10" more behind the seats than you had. I couldn't imagine driving it without it. For now I'm keeping the wall (less the walk through).
Vetter
Yes it was terrible for leg room, Ambo I was the same way. I'm 6'5", can't believe I dealt with that for 10 years, but my knees were a lot younger then! I will say this, I haven't even drove it this way yet, but I can tell already I'm going to like the openness to see out the back better.
Bikersmurf
I've got another 5" or so to spare behind the drivers seat. The seat is as far as it goes back... I haven't felt the need to so far.
Vetter
I spent the long weekend building a wall down the center of my pole barn, I'm only going to cement and heat half of it, still don't have electric in it yet, but soon. Can't wait to get my shop done!
I was able to spend some time on Ambo II, pulled out all the rear heat and AC stuff, glad I did the hoses were real soft, plus the heater core looked like it had a small leak, a lot of hose came out of that thing. Also pulled out the front interior and a lot of unnecessary wires, the floors look good, just need to sand and paint, then add some sound deadener.
Started cutting off the back overhang a little bit, I didn't think it necessary to cut all the way to the wheel well, Ambo I had about half the overhang as this unit and I never had a problem, plus this way I can keep a full door and only have to cut one door to the passenger side storage bin, the hinged side of the door will be the short side, so I will have to see how well it is supported, but I don't think it will be a issue.
Now I need to get electric ran in my shop so I can start welding up some of this aluminum, and making steal bumpers.
flipstick
