Looking to order a Krawler here in the next few weeks.  Spent the past few days devouring this thread.  Couple of questions for real life owners:
Where are you all stowing the sink?
Does anyone have pics of the swing away sparetire with sink?
Should I get spare on Teardrop or use spare on Tow vehicle?
Does the roof Rack/Basket interfeare with fan?  How about if an RTT is mounted?
Heater? too much?  worth the money?
Caged lockable storage?  what do you use this for?  Is there an option for a water proof version of this?
Extended tounge?  I really want a nimble trailer.  Does this options make the trailer to long?
Tongue box. What is in it?   Battery?
Does it come with inverter to run a laptop etc?
Rear bump rails?  DO they get in the way of cooking etc?  Bump knees?
Cabin shelving?  How is everyone storing thier stiuff?  Clothes?  Duffle bags etc.  Kind of thinking saving money on cabinets and just doing open storage with baskets etc.
Any sugestions?
We're new to the expedition trailer scene, but did quite a bit of research and reading before optioning ours.  Your needs may be different.  For us, we wanted a fairly basic trailer understanding we'd add options down the road as we needed them.  It's more costly this way, but also perhaps a bit more fun and got us started without breaking the bank.  As such, we didn't spring for quite a few of the options you list above, but probably will add some in the future as funds allow and once we've learned a bit more on how we like to camp.
Sink - Did not opt for.  We will use a collapsible backcountry sink for dishes.  Long term I plan on adding this with a water system.
Spare - Different pattern on trailer and tow vehicle, trailer spare when needed will be on top of 4Runner
Basket/Fan - We went with the Fantastic Fan, and have the SoCal brackets with a Yakima rack setup.  With MegaWarrior rack installed, the fan pops up enough to turn on (needs ~2" lift to actuate switch) and should be OK.  Will likely cut basket out and weld in frame to clear fan.
Heater - Don't plan on cold weather trips in the PNW, but trailer is comfortable down to high-30s with decent bedding.
Caged Storage - Will use this for camp chairs, firewood, chainsaw, and dirty hiking/cycling gear.  Like the idea of floor mat storage, I'm going to steal that.
Extended Tongue - Can't comment here yet, but would trust SoCal figured this out well given the intended use of the Krawler
Tongue Box - Did not opt for, partially to keep tongue weight lower so our Subaru could tow if desired.
Inverter - This is an option, but one we didn't spring for.  I've got an inverter I'll install down the road once I figure out what we need to power and where we want 110 available.
Bumper rails - Did not opt for.
Shelving - We went with standard shelving and lower flip doors.  Will be building in a retention system for books/clothes for upper bins.
As far as suggestions, chat with your builder.  Michael was really helpful in what to add now versus later.  When all was said and done, there are a few things I wish I would have added (LED ground lighting, for example) but otherwise feel we've got our needs covered fairly well.
If you're looking for long trips, MtnToSea seems to have things pretty well figured out.  As a side note, I'm pretty sure I saw his trailer being built when visiting SoCal in June in LA!
Good luck!
Adam
