Lets see some full size pictures...
RPhil
Vermejo
New Mexico Backroads' AEV Prospector
NMBR Prospector - 2016 RAM Power Wagon Tradesman equipped with 3" AEV DualSport SC Suspension, AEV Front/Rear Differential Covers, AEV Splash Guards, AEV Front Bumper, AEV Raised Air Intake w/ Pre-Filter Assembly, AEV Heat Reduction Hood, 17x8.5" AEV Salta HD Wheels, 37x12.5" BFGoodrich All-Terrain KO2 tires, and AEV Leather Seating
Raul B
First look at the cvt simmit series awning.... Posted a video about it on our @overlandf150 Instagram page...
Sent from my SM-G930T using Tapatalk
Mundo4x4Casa
West slope, N. Ser. Nev.
jefe's '01.5 RAM 2-series hard side Truck Camper, the XTC: drivetrain build
I finally finished my drivetrain build. There was a lot of testing and even some dead ends. The basics, almost none of which you can see:
'01.5 RAM 2500, 4WD, Cummins H.O., NV5600, 4.10 gears, 35" Cooper Disco AT3's, LT315/75R16 on steel wheels: front-7.5" wide, bead to bead; 6.25" backspacing; rear-10" wide bead to bead Stockton 'Power Wagon' steel wheels with 1/2" plate center hubs and 4.5" B.S.; Spyn Tec Dodge Dana 60 hub conversion kit, inner spindle bearing kit, new Dana 70 spindles, 35 spline outer stub shafts, Mile Marker Dana 70 Lockout hubs, factory ABS sensors and studs, Mosier 35 spline front Dana 70 long and short axle shaft conversion, Gen IV tie rod, drag link, TRE's, and stabilizer, new ball joints, a front 35 spline Eaton/Detreoit True trac torque biasing, gear driven limited slip, CAD and front unit bearing delete, Top Gun Customz longer control arms, the 6" inch lift version but installed on a 3" lift. Result is the axle is located 1-1/2" forward from stock. Rear axle: Dana 80 (11,000 pound capy), 35 spline, Eaton/DetroitTrue Trac, new driveshaft, 8-leaf rear springs, Stable Loads, Rancho 9K's. 3" loaded lift all around. In other words, the truck is about level with the camper on and loaded up. This is a pic taken on our shake down cruise to the Mammoth Caldera:
Our goal was to build a truck and hard side camper that would travel in any weather, during any season, over any road surface, or lack thereof, and fully support a pair of seasoned travelers for months at a time either boon docking or stealth camping in the city.
D45
Pushing the axle forward that far, how close is the axle to the track bar?
How did you compensate for the front sway bar?
xander69
