How to cover drill holes in van?
Oceantrav
Got a cargo van and it has the back up Mirrow thing hanging off the back corner. The one where you can see what's behind the van. I took off the mirror, but left the base/mount cause it is mounted with 4 bolts going through the side of the van. When I remove those bolts, what are my options for fixing/covering those holes?
Bbasso
Expedition goofball
Proper way would be to have them welded closed then painted (obviously lots of stages inbetween) or just body filler then paint...
mtnbike28
if flat surface, drill a bigger hole and use this - use for elec access or place a small fan in it!
tgreening
Easiest and most weather proof without welding/body work is to take a run to some place like Fastenal. Some button head stainless steel bolts with weather seals and you're good to go.
