My Rant
 I will say it again.... New Diesels require DEF...Which is an additional cost and more importantly additional weight . Then there is the availability factor.  In MOST of the world where you would actually be OVERLANDING instead of driving your Mall Crawler on freeways DEF will be difficult to procure; and therefore must be carried with you...hence weight now becomes an issue. But best of all... DEF has a relatively short shelf life, so it seems that you better just keep moving on down the road instead of actually camping remote or something, like an Overlander might do. If you are fine with staying on the accelerator instead of taking a few months to explore remote places and vast expanses so that your DEF does not degrade before you make it to a more "civilized" part of the world I guess it is not an issue.
 Taken from a DEF manufacturers website (Special emphasis on the important part):  "Diesel Exhaust Fluid doesn’t degrade nearly as quickly as people assume. For example, at 86°F, DEF has a shelf life of a year. REMEMBER: Do not equate shelf life to spoiling like food, as DEF will not go bad. IT will lose some effectiveness, and the SCR will dose at a higher rate, but it won’t “go bad.” If maintained at a constant temperature, DEF manages to stay for several months. For example, at 74°F in Los Angeles, Diesel Exhaust Fluid has the shelf life of 44 months."  The point? Just how is it going to be at a constant temp when you are traveling all over the world? DEF wont "spoil". but it will be consumed faster as it degrades and loses it's effectiveness. More DEF needed...more payload and less space. Lets keep in mind the effect weight has on fuel efficiency.
  Of course on the bigger rigs like my Ram 2500 the increased fuel economy just does not seem worth it. A diesel requires more maintenance than most newer gas engines.( For certain with Ram Trucks!) Figure in the cost of DEF and the additional $4K-$6k cost of the diesel motor and I just don't think it pays for itself unless it is constantly under heavy load; which is where the diesel becomes much more efficient. Yet a diesel engine uses more DEF under heavy loads. ( Feel free to read an owner's manual)  We all like the low end torque of a diesel especially well for technical off road driving, which would typically be done at low RPMs close to idle. However these newer diesel engines also have a regeneration process which burns off particulates , and that process requires higher RPMs to generate the heat needed to burn out the system. ( Again, feel free to read an owners manual) Here is what happens when you idle a modern diesel engine for a long period of time: A little light comes on and alerts you that your regen has failed and you will need to take the vehicle to the nearest dealer or shop for repairs. I have seen this happen at the dealerships I work at many times. In fact, I just had this exact thing happen on my 2016 New Holland tractor here on the farm after I had to idle it as I was working on the field! A little hard to find a dealer in the middle of nowhere! ( FYI, You can limit this problem with hard driving at high RPMs for 20- 30 minutes as the regen starts to fail. I see the techs do it all of the time to fix the issue and I did it to my tractor yesterday.  But what a pain in the butt!) MAYBE this is why you cannot get a Power Wagon, arguably the most capable full size truck off road, with a Diesel !
 All this said, I just dont see the value of a diesel Overland rig with these new diesel motors and emissions! I don't get much less fuel economy in my 6.4 L Hemi (Which I bought new) than my buddies with diesels do unless hauling heavy loads of 6k lbs or more. In 77,000 miles I have literally changed the oil 9 times, the air filter once and a set of tires. Front brake pads are about due as well as another air filter and a Transmission flush. With a very real difference of about 4 mpg, I have probably spent about $3800.00 more in fuel than I would have with the diesel; not including DEF. With the cost of maintenance(Really, check the owners manual) and the increased price for the diesel motor I am still ahead financially by a long shot! OH...and that fuel estimate is even presuming that the cost of Diesel and Gasoline are the same; which has not typically been the case over the past 2 years I have owned the truck!
 I absolutely want a new diesel truck! However, I want it for the Farm. If used for its intended purpose of hauling heavy loads, the modern diesel is a fine work of art. But for a purpose build expedition rig, I believe the only viable diesel motors are those without all of the modern emission controls for the reasons stated above. So I may need to carry more fuel than a diesel, but without the extra DEF and the issues of low RPM driving clogging the exhaust system, it seems much more sensible to have a new gasoline motor and use fuel stabilizers for extended periods. Feel free to try to change my mind.
