6g75
This portal and the posts helped me a lot while I made a decision to buy a Montero. Buying a Gen 3 with less miles was the objective and I was able to get one with 97K on it.
Got it checked from a mechanic before buying from the dealer(quotes KBB pricing ++) and he noticed some oil leak from the Valve Gasket and other then that it was just fine. Make sure to check the transmission and 4x4.
I did about 2K over a period of time and the only repair it threw at me was 02 sensor changed and got the fluids changed. I knew the timing belt had to be changed and was budgeting for it. Also had plans to get new plugs with that job.
Just copying and pasting from a post I wrote on - 3rd Gen Montero Questions post from offthepath
http://www.expeditionportal.com/forum/threads/159055-3rd-Gen-Montero-Questions/page6
Yesterday was a nice and sunny Saturday and thought it would be a good time to go out for a weekend drive. So it was Texas hill country and about 200 miles for the drive. These are curvy roads but with 60 MPH speed limits. It was all going well and we were getting back to enjoy the Saturday evening. After a heavy lunch, I don't know why(maybe laziness), I happened to start using the cruise control(CC) and yes, this is a hilly area.
So as we were approaching a hill, the CC revved up heavy to control the speed(I didn't feel a downshift). I felt there was some loss in power but things were ok after that. We drove about a mile to a 4 way intersection with a STOP sign. While braking here I felt the CC was still trying to power the vehicle. Then we stopped. The A/C was on at full blast and I pressed the accelerator and the we wouldn't move. About 20 seconds and put off the a/c to notice the engine stopped. I restarted the engine and immediately felt a noise coming from the engine and the car moved with resistance to a place nearby(luckily there was some shade for the 100F temp).
I got out and thought let's simply give it some time. After 10 minutes, tried to start but the same noise and the engine stalled. It was a Saturday and that place had not internet. Walked into a local Bar and asked help. Great people, they managed to have a local mechanic arrive. So all this took about 30 minutes. He then asked me to start the engine and I did. He checks the oil(no problem) and he also check the Engine oil light(no problem). The engine started this time but there was that noise. Our man, makes a sad face and says, it's bad.
So he says the Rod bearing's gone.
He didn't even charge me and I thanked him for the help. Managed to get it towed home where it stands now. Got up in the morning today and managed to record the noise for cold start and when the engine was warmed up. Here they are
I got many responses to my queries and although they were helpful, a visit to 3 mechanics confirmed that it was a bottom end issue. Why --? There was oil and the engine oil light works fine and it never lit. So their rational explanation was, the previous owner might have missed oil changes and the damage was already done earlier and it was an issue of time.
I still think(X-Files), type of an issue might be the reason and there is a similar mention here
http://www.automotiveforums.com/t918306-codes_p0174_p0171_and_p0327_help____.html
“Right before the motor went out I was pulling a boat with cruise control on, when I was approaching an overpass the motor raved up like it does with cruise control on, but when I got to the top of the overpass the motor didn''t slow down like it should have so I had to stop it myself. An that''s when the motor spun a rear main bearing.”
That aside, what do you do? You paid prime $$$'s and you've used it for 3K miles and you have this issue. My choices were try a used engine or go for a remanufactured engine.
I don't want to reason but I went with a Remanufactured engine and it's done about 1.3K since installation. In this thread I wanted to share my experiences as they happened when I decided to get a remanufactured motor to an ongoing thread. Wish me luck…
