Puma 12v Compressor SE NY
Titanpat57
Puma 12 Volt 1.5 Gallon Oil-Less Air Compressor , Oil less 12V Comes with 10' leads and battery clamps, ready to work
Hooked up ready to go, used a few times....upgraded to Twin ARB...saving my air hose and end to use on the new compressor
$185 Pick up only...thanks for looking
adventr
I'm definitely not close enough to pick this thing up from you, but I was wondering how it compares to the ARB twin compressor?
Titanpat57
I'll report back once I get the new one hooked up.
The one thing about the Puma, is more then once I've used it for running a nailgun...fun setup for sure.
Dont know if the ARB can pull that of...I guess if i installed a pressure switch and tank. I plan to mount the ARB under the hood on my @bandi mount
DanoWall
