2004 Tundra Adventure Cab - Build/Adventure Thread
Samiman
Carefully cut up the original tundra outer cv joint and swap the center section that the 6 balls center the piece on. They should all be the same. If you don't have a stock tundra shaft shoot me a text cause I think I saved the ones from my shafts. I live in Vacaville and my cell is 7075923342. Nick
The diff spline count is the same on both axles as well as the hub splines. It's the internal splines that were changed on the aftermarket shafts.
toyotech
The outer cv joints don't come off? They have to be cut to be removed?
I know my axles are OEM. Well I'm pretty sure lol. I rebooted them with Toyota boots. Do you know if the aftermarket taco outer will fit the Toyota Tundra shaft. I'm worry that the aftermarket taco outer joint is 27 spline?
toyotech
Sorry I been MIA. Been sick for almost two weeks before checking in with a dr who tells me I have walking pneumonia. So Parts have been sitting till I get better. I took over archive/deaver leaf spring project. Will need to install them and start seeing what changes if any is needed.
Than I got the manual hubs I need to get swapped in. Excited for both these mods
toyotech
Archives garage expo pack !!
toyotech
Price is TBD once testing is done. The Archive Expo pack is installed and my info has been sent it. The pack needs to be reworked. It's still shy of the lift its suppose to give.
So install photos to hold you guys out. Hopefully they come up with a solution soon so I can get the pack fine tuned.
The springs are designed to work with archive garage SFK as the springs are an inch longer. I'm actually excited to see that it's not just a heavy duty back but also longer. This should help with ride and flex.
Up in the air and ready to tear the old stuff out.
toyotech
Curious to see what you find Bro-se
It rides great. Much better than the stock pack and 3 leaf. But the test pack needs work. I'm actually sitting lower than before lol. Waiting on Eric at archive garage to see what the next steps are
Your old springs look way better than mine do.
My truck was a mall crawler before i got it. The stock pack you see still has the 3 leaf AAL installed
On a side note I weight my truck earlier today. Full fuel tank with no camping gear in bed. I'm right at ~6000lbs. Front ~3000lbs and rear ~3000lbs
theBullfrog125
6000# is a pretty good dd weight. My T100 loaded down with camping gear (no sliders or rear swing out w/ spare) tips the scales at 5600#. And you have a V8! Haha
trailscape
I'm thinking mine may have been used commercially. In the right lighting I can almost make out some fading that could have been lettering on the door. Also, some rivnuts installed in the bed an some existing radio wiring.
rickashay
Wow Jose, I'm surprised you are still sitting low. They definitely rode nice for me too but they were just too low. I thought the extra leaves were going to be the ticket. Curious how this all unfolds, I'm sure Eric and Deaver will get it figured out though.
Joseph McCormack
