Help! Isuzu broken down (again)
IGBT
We fixed our injector problem in North Dakota by having two injectors replaced, but now our 2006 Isuzu NRR 5.2L 4cyl diesel has an engine light again.
It is throwing code P238, which has to do with turbo high pressure sensing. It does this right when you crank the engine and erasing the code has it pop back up immediately.
The truck runs, we drove it 120 miles, but the top speed is now about 50mph and it can barely go up hills. Admittedly it was never speedy with our 18,500 pound load but it was able to do 65 or 70 on a flat.
We are near a truck shop in Dothan, Alabama which does work on Isuzu but this would involve removing both pods from the flatbed, which takes a couple of hours, then a couple hours to re-pod. If this is just a boost sensor, loose cable, or something that I can get to myself, it would save us a ton of work.
Any ideas?
SkiFreak
Crazy Person
Computer controlled equipment is arguably superior to manual systems, but when it goes wrong it can be a royal PITA!!!
Sadly, automotive technology will likely never go back to the simplistic systems they once were.
kerry
In thinking about it, it can't really be high turbo boost if it happens right when the engine starts so it points to a bad sensor or bad connection.
IGBT
FIXED! (Help! Isuzu broken down)
We fixed the problem ourselves (it was quite easy).
Instead of removing the pods from the flatbed, we decided to try raising the living pod high enough to tilt forward the cab. It worked great and only took a few minutes (mostly to dig out the jacks from the truck boxes and plug them into the pod sockets). It seems that raising the pod about 10 inches off the flatbed was just right for tilting the cab and it not hitting the overhang.
Once the engine was exposed the problem was extremely obvious. The boost sensor wires were all frazzled (the red and white totally torn through, ground was nicked). Squirrel or mouse or just vibration? Anyway, I broke out the soldering iron and heat shrink, performed some surgery and she seems to be running fine now with no codes. $0 spent. When does *THAT* ever happen?
Truck kind of looks like a transformer here:
SkiFreak
Crazy Person
It happens when people make an effort to do maintenance or repairs themselves, opposed to taking their truck to someone else.
The bonus of this approach is that you know exactly what work has and has not been done.
Good job!
kerry
Great news. Almost always better to do it yourself if you can, if for no other reason than educational ones.
kerry
Did you sail with the West Coast Trailer Sailing Squadron? They do a lot of nice trips on the west coast of Florida. We're considering towing our Sea Pearl 21 Tri down to the Gulf Coast of Texas in late January.
IGBT
We sailed out of Carabelle, FL on the gulf side and Saint Augustine on the Atlantic. Solo though, not with any group.
We will also be heading to Texas gulf area to sail this January. Have not picked an area yet, but maybe Rockport?
kerry
Rockport is nice. We have our eye on Port O connor. There's a state park out on the barrier island only accessible by water. Army Hole is the name of the anchorage there.
DFWSFO
