Griffin Adventure Trailer
kcdeming
Hey Guys!
Long story short, we exhibited at Overland Expo East this year and it was a fantastic show! It was such a fantastic show we decided we would go to Overland Expo West in Flagstaff, AZ next May! Just to give you an idea of what sort of obligation that is.. We are located in Smyrna, GA. That means we have a 1,773 mile commute to the expo...one way. THEN you throw a 2-year old into that mix and you have a recipe for adventure OR disaster. Either way we are looking forward to the trek!
NOW that we are committed to the trip we need to add some more space for all of our camping gear. Currently, we will be taking our 2013 F-150 Super Crew but with the booth and merchandise we need more room.
I have always wanted an expedition type trailer so the Craiglist hunt began. We found a used enclosed 4x6 trailer for $700. Come to find out this trailer is a retired Police Radar trailer made by Kustom Accessories back in 2001. Some benefits to this trailer was it's size, axle, and new tires. With some imagining, this trailer's new purpose would come to light.
The first upgrade we did to the trailer was install some Yakima Racks on top of it and hooked up our CVT Mt. Rainer on top.
Stay tuned for more updates!
Phxdsrtrat
You'll love Expo West. They are moving to a new site this year I am unfamiliar with but I'm sure its great.
That little trailer looks like it will work well.
-Curtiss
kcdeming
-Curtiss
Yep! Already signed up and planning my trip now! Lots of updates on the trailer to post and much more planned for the spring! Get ready! This May is going to be a blast!!
kcdeming
Spring Update
Trailer updates since our last post:
-Added Yakima Rack / Bomb Proof Mounts
-Mounted CVT MT Rainer RTT
-Completely gutted the previous wiring and rewired lights added a 7-pin connector.
-Added two aux LED lights on either side and connected them to new Deep Cycle battery.
-Changed out the old chrome rims and tires with new tires and black rims from a friend's trailer build.
-Painted and vinyl logoed exterior.
Now that Overland Expo West is right around the corner, we have ramped up the build to travel 1,800 miles (Each Way) from GA to AZ.
What's up next:
Water
-Camp Chef Triton Water Heater (Ordered)
-Self Priming Pump 2.8 Gallons/min 45 PSIN 12 V (Ordered)
-20 Gallon water reservoir.
-Water lines
-Pelican 1550 Case for Water Heater
Electrical
-Electrical system components:
Relay 12v 30a Spdt 5pin Pack of 5 (Ordered)
HELLA H84988011 7-Way Mini Relay Box Kit (Ordered)
Blue Sea Systems ST Blade ATO/ATC Fuse Blocks (Ordered)
Digital Display Voltmeter Waterproof Voltage Meter Green (Ordered)
Goal Zero Bolder 30 Panel and Goal Zero Guardian 12V Plus Charge Controller (Ordered)
Near Future:
-Cut off rear panel and build door and slide system.
-Awning with LED Lighting.
-Speaker system.
kcdeming
Cut off the rear panel and built a door!
Installed the Camp Chef shower into the Pelican box and installed the water ports.
Attached the water system together. We are using a 18 gallon tank with a 12v marine pump.
kcdeming
Electrical switch box in the pelican for the exterior.
Closer look at the water in and out port.
Added a lock for the back door.
Closer look at the shower attached inside of the pelican box.
