1988 range rover classic moderate build
krnnerdboy
SOLD TO A MEMBER! THANK YOU
200k mi on chassis
No documentation on engine rebuild, but around 160k mi
1 year since knuckle rebuild(documented)
Runs well
I drive it regularly to my cabin in lake Arrowhead
Exterior 6/10
Interior 5/10
The build
Safari gard front winch bumper
Safari gard rear bumper
Garvin xl roof rack (spare, Jerry, axe, hilift mounts)
Mantec snorkel
Ome HD Springs
Ome nitrocharger shocks
31" big at 50%
Dual battery setup
4000 watt power inverter
The bad
Passenger seat doesn't adjust
Use of the heater causes a scent of coolant
Windshield wiper motor was burnt out on new years from heavy snow
Cold start has intermittent issues that's overcome by leaving the key in on position for 30 seconds
krnnerdboy
Any rust or major damage to the car?
No known accidents or telltale signs and the only rust that I see is on the rear window hatch area, which I am currently in the process of sourcing out. Also checked floor pans and there is no sign of rust
krnnerdboy
Any interior pics?
My apologies, I just saw this message. I'll have themy up tomorrow.
On a side note, I just did a day trip out to cleghorn and did some wheeling. The car ran phenomenally and is really well sorted on the trail or the road.
Replaced the coolant sensor with new spark plugs and it has fixed the cold start issue! Seems to run a little warm when climbing long stretches, so I'll be doing a coolant flush and leak down test on the cooling system
