Mounting options for a water tank to a trailer?
I'm thinking of welding a few tabs to the frame and using fuel tank straps so I can mount it under the bed of the trailer? Good idea? What else have you guys done?
dstock
I'm not sure if I am going to weld them or bolt them but looking at doing the same on my trailer. For sure the tank is going under the bed, I don't want to give up the bed space.
Martyinco
When I get my water tank made I will be mounting it below the trailer and make a simple steel skid plate for it. My plan is pretty much like your, tabs and a strap to hold it up in place.
Nd4SpdSe
Adventurer, eh?
I made a, well, I'm not sure what I would call it, a rack or a basket? I still need to get some proper straps on it, but it does the job. It also pivots at the rear so I can easily install and remove the tank by myself.
woodienut
I put mine behind my battery/toolbox on the tongue. It's a little higher CG but well protected. Holds 12 gallons, ordered it on line from Utah I believe for about $80.00? A rotation molding place.
Henrybrowne
