TeraFlex Falcon Shocks and Nexus Steering Stabilizer
Greg@RME
We were lucky enough to get our hands on a set of the new Teraflex Falcon 2.1 mono-shocks and Falcon Nexus steering stabilizer for the RME JKU!! The Falcons are JK-specific shocks, they have a big of 2.25" body and massive 3/4" shock shaft, plus they're loaded with Redline synthetic shock oil and are fully serviceable and rebuildable. Teraflex really knocked the ball out of the park with these! The best part? They're hand-built right in West Jordan, Utah by offroad enthusiasts like you and I!
First off, the packaging was top-notch! You can tell that TeraFlex takes pride in these Falcon Shocks just by the way they're boxed up. I really like the step-by-step install instructions they include inside the box, lots of small details to help with bolting them on. I carefully unpacked the Falcons and took a few pics.
Each box comes with a note signed by the people that hand built the Falcon shocks and Nexus stabilizer, pretty neat to see who's handiwork you've received.
First impression was that these are like nothing else out there, very well designed and engineered.
Quick video about the build details...
Install happening now and full long term test and review will be posted in this thread. Hoping to get to Moab tomorrow and start the trail testing!
hmmwv
Those look awesome. I'm sure they'll perform as good as they look.
Sent from my Pixel XL using Tapatalk
Greg@RME
Considering how well they are engineered and the fact that they're easily the best shock out there for the JK, I think they'll be great.... but time will tell! ;)
I'll be sure to update this thread with a review as time and the miles go by.
Greg@RME
And my written review...
So the very first thing we noticed was the new handling characteristics on the freeway... between the Nexus steering stabilizer and the Falcon shocks, the entire Jeep felt much more planted at freeway speeds. Hitting a big rolling bump on the freeway, which before would toss & rock the Jeep around, now made the Jeep react composed and stable. The suspension would compress and then decompress and the Jeep would recover with hardly any drama. Within the first 10 miles my wife in the passenger seat mentioned how different the Wrangler now rode. On I70, heading towards Moab in Utah the speed limit is 80 MPH... previously, my JK rode OK but at speeds over 72-73 (actual speed) the Jeep was a little 'wobbly'. Now with the Falcon shocks and Nexus stabilizer, the Jeep was absolutely planted at up to 85 MPH! Driving over bridges and expansion joints before would create a little wobble in the steering wheel and with the Nexus steering stabilizer, the steering wheel is totally firm.... it doesn't show any indication of upsetting the Jeep. We do a lot of on-road driving to get to destinations, from driving out to the Rubicon last Summer to our trip down to Baja and back, having a Jeep that handles well on the road is very important to me. I still need to put some longer road miles on, but I think long drives will be less stressful due to the way the JKU now drives. This is how a lifted Jeep should ride!
Offroad the result is similar, when you hit a big rock or drop off a ledge the suspension does it's thing and the Falcon shocks control the body sway and unwanted movement with little drama. The suspension reacts and the Falcons control the suspension better than any lesser shocks. You don't get that rocking & rolling that sometimes happens offroad. At a few different places in Moab, we were able to shift into 2 High and get some speed up and the control that the Falcons added to an already good suspension was now impressive... I could drive a lot faster than I should! It wasn't really warm out, but after a little high-speed driving the shocks seemed very liner with their performance. No changes after trying to get them heated up. I still need to do further high-speed driving to get a better feel for their performance at speed.
One of the things I love about the Nexus stabilizer is how it works with the stock (or upgraded) tie rod, but now is relocated above the axle centerline and behind the tie rod, out of harms way. I've destroyed 2 steering stabilizers in the last couple years in the stock location and feel like the raised Nexus will be very well protected. Also, combining the axle end mount of the Nexus stabilizer with the track bar mount/bolt is genius as well, great use of a big bolt hole!
To wrap it all up, I think the Falcon shocks and Nexus steering stabilizer are nothing short of damn impressive. I doubt there is a better JK shock & stabilizer out there, bolt a set on your JK/JKU and you'll instantly see the difference in how your Wrangler works on road and off.
Alphonse
I like the idea of the front shock. A lot! They put the reservoir right where I almost put mine because piggy backed my front reservoir always rubbed the tire no matter how I turned it.
The back reservoir, well I'm just not a fan. There reasoning is clear but they should go back to the drawing board and find another way. Part of me believes they wanted the reservoir where it could be seen for the ever growing mall crawler crowd. The rear reservoir is hanging down like a boat anchor even in their video showing how tough it is it's still a liability to get hung up on even if it can handle abuse. We go to great lengths to lift our jeeps and tummy tuck and raise control arm and shock mounts.
This is a huge step backwards except for mall crawlers who want to be showing their reservoirs...
Greg@RME
I know what you're saying, after the Rubicon my rear-lower shocks mounts took a lot of abuse!
The biggest reason for the rear shock bodies being down is to keep the shock shaft from getting beat-up by rocks, dirt, road-grime & debris that would get kicked up from the front tires. A beat up shock shaft ends up tearing up the shock seal & they start leaking pretty quickly. TeraFlex has built these Falcons to take a beating, they know what we're going to do to them... the aluminum body is built with "Type 3 Hard Anodized" which is incredibly hard for superior protection. Plus, the lower mount is built to pivot around, so the shock has some give and it will deflect out of the way it if it gets hung up. The thickness of the body cap and the body is also extremely overkill to take a beating and keep on going. These aren't cheap, stamped steel shock bodies.
Also, moving the shock inward towards the wheel/tire offers even more protection. With these 2.1 mono-shocks, the bottom of the shock body is very well protected by the shock mount... you could possibly back up and run the shock into a rock, but you would have to try VERY hard and at that point, the beefy build quality comes into play. For the 3.3 Adjustable Piggyback Shock with the reservoir built on the bottom, I understand they are working on a bolt on skid plate that contours the body cap and extends to provide extra protection for the adjusters and will help further protect your investment.
This photo is taken directly from behind the shock... you can see how protected the shock body is behind the mount and close to the wheel.
And if you haven't seen it, check out this video... they show the 3.1 Piggyback Shock with the reservoir built on the bottom taking on a rock ledge. You can see how the shock pivots out of the way, then the rock breaks off...
There's always the option of the Falcon 2.1 Monoshock like I am running. That way there is no Reservoir that you have to deal with and you still get the strength and most of the performance benefits.
Greg@RME
Do you know the difference between the 2.1 and the Sport 2.1?
Yes, from Joe @ Teraflex...
The 2.1 is what 85% of the customers will want. The Sport 2.1 will have a more aggressive valving to them, so they will be better for the go-fast, offroad Baja drivers. The 2.1 is really the best one out of the 2.
kojackJKU
Autism Family Travellers!
Hmmmm, new jeep for me??????? Falcon equipped willys in that new tan color. Uh oh!!!!!! Damn, it's only money!
zhukoveli
