What did you do to your Expo Jeep today?
XJSuperman
OhIOWAn
Don't take it so seriously.
I couldn't respond about the lights, and call them SQUARE myself.
Simply couldn't do it....... :coffeedrink:
While obviously not technically correct, its correct as in "jeep with square headlights" or "save the squares" or not round but ______".
IdaSHO
IDACAMPER
Perhaps that's why I have a Jeep with ROUND headlights :sombrero:
AgentOrange76
That garage is awesome man.....we're doing the same thing to our greenhouse to convert it to a bunkhouse but its not nearly as nice....
The levitating Jeep is cool, you know until they install a magnetic rails in all the roads it won't do you much good :D Super cool barn by the way....
_R700_
Did a 12,000km round trip in my JK and only drove through 3 states and only saw a tiny portion of Australia.
Here's a few pics :)
Z65crT6CXgC3W3LIfLHJ1F5NlAm1B48tXTmuzt0-siXb9Nuzty7zoofQgVWt3YCxQI_E3l3bVnYbhHvIzphAX9ERcPToLBsOkDZpVMYX-Oxy36i_Wh9GmfU7DRLpPidmCW2BBDH_4qbKWr_fK85P1LEkVKKi9J_LP4wnQiTpfPdduEkMzJY97mfN8tY5pTFFZEXaqYSmlpsyZCLsG83iqOgtUU-QO99_yUlHorctG1FxfQIHf8j7ylRbnz2hMtYblbpqu_Dz7iEUgcExRpRZ1TvONo0N2hcju_o8sGXIRZQNoVHZQy-ZSxOVl7LHdf4mTL4BxFzpAsu-RAs3IDaNniwPTW_GD3j8cA68I60kAJepg2JiGWMB1cr5zRaaARK6Hb7ma3jdXBWmZZMAQet8dMGZj5qv4EzFJWAC9yu7BgKga8LdEyLUaWadr_BdoaAd8eJda7iGjyHjVMJvQerMM0YNajX16LHKuf3MLrTQqi2UesX9bu0s4VYqYkWg21Buy4XVxzGzqHJsDB363kBDGmT9m8mXY4mqqxXAuIKZRUn0ZIzTWtqWcppkEsqQUMtXPxoBoLQGsK1PW3ftCY-jGDyzS96siVLc9rFK-E32hEYRJrlhhuF9KRTo8_K4zOMHbz041gSkC-AZmb6EuAcw9K-GgRO1il0SVqSOGfBhJdQ=w1472-h767-no
cif6g4eDJzzRe6Fp5QulV1xNGfrbreD6_jnx7HdbDRw6ilAMMbLgZnDxfcS6-P4F9JF0BmRkdQjPBPqSwicFKgfUz-5K9bfpOBzxf-knTdGMnnvDcXBERyUY3kFTk3VHtIA1QAgW6tar4Vx3kE1SwSWADEfCQbFS051UdSlRsRo_BFzDZdaUBpB2_OmY5vHQ1WwiT0dvLNf5cIvNQ3GpS1n-0VRoI0UFLZQ9sjG8BSH-63ax6qAsoTCKah-ZbX-1d2mPRcCHNu3xi8knZ_Xt_Fro3pZ_nPo1i41_hrBEobrqq9HSfaU979jk_O_Zg4IN0YgZbNcH-MHcIad-vMr3JjxGGLZ9uDzEVMSWOzvVdHHq5cncNhcE4Wf7CdFm0kKxse6d89QSQ0doqiTdOds55daY2uOElsTf0Mkj33Pv0Mu5HV1LbV5_gDghJbW-uO8WPzbP79a4MhiUkwyQIq0auAn63VgteUH-m_0aRc9k2r5kZ9FWy5uDGIdwVE2RUmsL5FlH7iSQRbbp7uu2UyqbCslWF_f6wdiWJ3fiF2LofYQFR7Js-1uLH0x6WuCkL6-mowDJmQ2i7RkNpBdpdNLMtbkoZugp1bzNBYeh80mIsR7-FjId7QOswTUBcMIyMM-zA28eI9Rj30Kk_n1jS0y9UBClZetZKGQz3L0nT8-i4Ko=w1374-h873-no
lEV4npZoN7TcHkFgGPENCkALzu_2cVfrFMui0exGbo8aLc4m1ToOcWpCGRR7d4NR2UcQzGs9NJQW7WYK-8dxiV9QsEHKuVCXfd8Y0lE1CSwT7HYlDi8IoPpNAV0SNFFHzY7qOeaErIaZherpJ-xEyr-7xHmriwGqUouid3UaXGmGm38QFpu6VjxJMT3pSETnhr5LYJVqaSHXePi29Kqf4LZ4Z4S7NbZ1eojkVY9JmOOCmpDJlUIV3veYTYQff3xgat8xrvGq1OmVJvOE2A_PQKu0lxuMkXsdrxjtPnVq92OH9J9DXkOuXzkfLrtseVNvEHHy2vhS7oHMldxMxORuXxhwvsWNBDdip0CL-MtY6P-S2Cj2wmGhCuJ3lHuqWjmosn2DEfgy0fwec76dlXC7IbY48FGZbiyTxyiDXG3g7h3etergp_YzF7O1L8tp2bcl4SVp4FUKb73M_c3ooIf7aOCJb6eRB591voLj7dHVJPSGrbxtcBjQDw2Av4zI3CrpctlGSHpAiKFd3OJiSoNxa8cd-nY9l4XUXx_xXw49suzTumeyVqNnWhXE2wuWiz-4u3yvlCjPUoQcnyJ_XqCDPwJRbKjuHZc-78P41MfLHlsjDzKLTI87nPu-6pPhOLXOyT9-JeipJz-QQ_sVjJOA9ivQfPrZZ8DUhzzfB2LaUM0=w1310-h873-no
OZ8evJ7if5Nd4PjXwei_DgKTWFFYi46yDO64-X2WQVbebTJsZ_cBH_Ps8pLYNGcN5-oxQ8LkX7HHl4CXYEO1AG9EazzA6WHrpJeAdrETVgOHHmCWEKzMd2dvlW-2OklAbjeOgB9B379ZycO8o2quMf7IrVgepnVV-3Aed9ornrAu2s-DePNLQ7gIBMgklBmZ3wlC_re0yz8O229Ipw9t46RvH-5A9sK5g5zGQkBiyY_NIEx2brqbZ7HX0wh8njUOMGmBaoYDnRTtuIxthXhDPN2GwBaF-R7WGwzxVwLK4nlJ6RtA3cSvW0Hb3EZISHpcrpCqDFCIsN0MputpiN-LwfufgugMhRlReSMjXQFnqburNvaHwfCrfnTTj_2NZVMUM2ntzkLe5rTPHUbh9vKp4wbEei3v_yarqdjW2vra3L8U8UlyQwpxEu-rfyXT99G1bWRNX-IJzYyh1ButN6bZNgn1qNduzuUHFcm3T-2n8k55vMuS6rmSXLtJN84eByoyMQgeYIziAINarWVszhasA3ZXmEITwDr72g4GAdXoRFGAt4IwP8w67Q8VM2t9ownsx0dBxibJv6v7rLdcjUHWQ6alnDEtT5M2oulJycILj7A4JKY1Yvi8jamFtPCEVuDN6yAm5efMlBB6250o9WgzNyjdIALMCfzRDg-mMyeYFco=w1310-h873-no
ratled
Honey do's are done, packages started to show up so I finally started to build... er bolt things
and more coming fast
ratled
ps NICE shots 700
Genesis dual battery kit with twin Odyssey 1500's
Winch started to go in but the 10th anniversary plate kit needed a fairlead adapter so it will have to wait a week to get finished
With dual batteries, a SPod (being installed now) and an ARB compressor (next) under the hood need to to slow down the bad guys. A Bolt hood lock
cyoos
Yesterdays progress on my so far 3-1/2 year 8.8 project ...
While tightening the 8.8's cross pin lock bolt the cheesy socket I was using went "TING!" and split down the side. It slightly rounded the corners on the bolt head, but I was able to get a long neck six point box end on it and hit it with German torque in lieu of the originally intended 22 ft lbs. It's "Guten Tight" now.
Before putting the axles in I needed to flip the drivers parking brake adjuster so the star nut could be accessed through the hole in the backing plate. Rather than fighting the high tension springs, I used a leaf spring center bolt with a nut and a washer to spread the brake pads. I just slipped the slot on the leaf spring bolt head onto the edge of one brake shoe and the washer backed up by the nut against the edge of the other brake shoe. Then I was able to wrench the nut around as though loosening it, and it spread the brake shoes apart enabling me to remove the adjuster and flip it around.
Dr. Marneaus
Station Wagoneer
Installed a new properly sized AC delete alternator v belt and a new power steering v belt since i was already in there and had to take it off anyway.
oskarf150
