Victory_Overland
What washer bottle and bracket did you use?
The one that came with the washer bottle I ordered off Amazon Eric suggested. It is just a single aluminum strap with bolt then drilled a hole and mounted it. Mine is under the hood right next to the coolant reservoir. It will have to be relocated if I put on-board air or dual battery charger in but works perfect there for now.
