Can I really not grease my u-joints gen3
1morebike
I just changed my oil and wanted to grease my u-joints but I can't find any grease ports. Maybe I just special or are they not greasable?
Inyo_man
Don't piss down my back and tell me it's raining.
The only serviceable u-joint on my 2002 was on the front drive shaft.
I've since replaced it with a non-serviceable unit.
Michael Brown
You followed me, so now we're both lost
There is a grease fitting on the front driveshaft, but the rear shaft uses CV joints that do not get serviced. All of the factory ball joints have also been sealed units. As long as the boot is not torn, the grease inside will be safe. Mitsubishi seems to have designed them for easier replacement using bolt in units instead of being pressed into the A-arms. It is not as common for these bolt in units to have grease fittings.
Henrybrowne
