SOLD -1995 Toyota Landcruiser w/ 4BT Cummins 3.9L Turbo Diesel, AZ
LandCruiserPhil
The countries visited says some about the ability of this set up Land Cruiser
A real expedition vehicle with the history to prove it, not just a poser
OverlandTheWorld
OverlandTheWorld.com
Goddamn, this truck seems incredible. Hell of a rig for whoever buys it. GLWS.
Thanks Roody!
UPDATES:
It will be featured in a few presentations at Overland Expo 2017 in May.
I've finally found a good diesel mechanic to address a few of the leaks on the vac pump and a few lines. It's much cleaner now
OverlandTheWorld
FAQ: I've had some common questions asked, so here are the answers
Q: How loud is it, how insulated is the vehicle? A: There is a video on YouTube of the inside at idle with the door open, but it might be hard to compare relative volumes. I used 5 gallons of acoustic deadening from Second Skin, it's a spray/roll on polymer. I also added 4-5 gallons of a thermal block coating that has ceramic micro beads to keep the cabin temps insulated. Also by Second Skin, IIRC it's like $87/gal. These are through out the tub and doors. I then added silver backed fiber insulation where I could fit it, then installed a whole new Mass-backed Carpet kit throughout. I then replaced all the door and window seals that were old to help seal out the road noise. I'm pretty positive you won't find another 4BT swap that has gone to this effort for sound, as just this required over 120+ hours by me. No shop could ever justify the time needed. It is as quiet as you can ever get inside of a mechanical injection rig. That being said, I've owned a GX470 and LX450 and they are obviously quieter in stock form. Side benefit is that the cabin is also insulated very well. I also have a UV & Infrared blocking tint that reflects most heat from the glass ($700 for tint).
Q: I heard 4BTs vibrate a lot? A: As for vibrations, I added a silicone Fluidampr Harmonic Balancer and along with a slightly higher idle, it doesn't vibrate like most most 4bts.
Q: I heard 4BTs are slow? A: As for highway driving: it's certainly not a speed demon, but I've had it over 90mph with no vibrations. The turbo and gearing are really set-up do go 70-75mph or less, like most 4speed autos, its sweet spot is around 60MPH for max fuel efficiency. Given the weight of the vehicle, it is surprisingly fast. The turbo starts to pull around 5psi until 22psi max. I've driven an OEM turbo diesel 1990 1HDT 80 series and mine is significantly faster. You won't win any drag races, but it gets out of its way pretty well for highway on ramps. It has minimal turbo lag compared to an HX35, which is the OEM turbo for Cummins.
I'd urge you to come drive it, if you are interested. There isn't a good way to compare it to another Landcruiser, as there isn't anything else like it.
portillagee
Incredible rig. We wouldn't mind having this in place of our Sprinter but we really wouldn't do this vehicle justice. It needs to be on the PanAm!
Good luck with the sale.
portillagee
1995 Toyota Landcruiser w/ 4BT Cummins 3.9L Turbo Diesel Conversion, Interior Build
@portillagee , Thanks! I think we wouldn't mind a Sprinter for our next trip.
I'll be posting ours for sale shortly, actually. It's not 4x4 but it is a 2014 Crew, 144" wheelbase, high roof, with under 30k on the odometer. Fully insulated from tip to tail, 10' Fiamma, Fantastic-Vent, and platform bed. And it's not white!
Our original plan was to build it out but we'd like to downsize to a smaller van now. We had our fun in it but decided we were being a little too luxe treating ourselves to a van like that. :).
OverlandTheWorld
Weekend bump, headed to Mexico.
We just got the cruiser back from the Mechanic with a $1200 service: Fluids, new vac pump, sealed oil pan, fixed a few leaking seals & o-rings, new AGM battery, minor adjustments, etc. It's ready to go.
tracknod
Hey Jeff,
PM me as I am EXTREAMLY interested. Do you want a '68 vette convertible in trade? This is an UNEDITED picture just out of the camera....
gp01
