Coachgeo
I have an LMTV. Frame/Chassis appears to have be same width as a Freightliner with an Ambulance box. Soo... I bought the box only including all the mounting hardware.
This is Freightliner with the boxes mounting hardware still attached. You see them bolted to the chassis. They have the round disk and pad on them.
The bottom of the Ambo Box has threaded studs thru a solid bar that slide into the holes on the brackets shown in above pics. Above is image that shows the studs protuding long aluminum bar across bottom of box
On the LMTV version that had a permanent box attached it used captive springs at the front and no springs at rear. Think there was two... maybe three total attach points. Only front was captive spring. Granted the "front" of that LMTV box was further back on the chassis than my first set of brackets will be when mounting this Ambulance box.
Something like this... (not from an LMTV but clearest picture I could find)
Sooo.. Armed with this information I am looking for suggestions on following plan.
1. remove some bolts from below ambulance and replace with ones long enough to handle captive spring.
2. attach brackets to my chassis matching the spacing of those on the box.... modify them if needed to use a captive spring mount.
3. Do I have to have springs above and below each bracket to allow for movement up or down.... or will just below suffice? I've seen both designs used in here.
So questions are....
. Is this captive spring idea is a good way to go? Why... Why not?
. How to determine spring and bolt sizing of captive spring?
. How to prevent corrosion issues between dissimilar metals (bolts vs Aluminum Ambo Box vs steel of brackets used on chassis. )
. looking at those mount images from Freightliner... and modification ideas for use with captive spring?
. There is 5 mounts on each side..... how many would you recommend I change to captive spring? PS- Yes I do plan to go off road that will get some twisting of chassis. NO mall / KOA campground cruiser being built with this.
