2005 F-450 4x4 Utility Body w/ Starcraft Pine Mountain Lonestar Pop-top Camper
PNWINFERNOPRO
@PNWINFERNOPRO
Swapped the bumper light covers for amber. Excuse the challenging lighting of the pics this morning. Can't wait for the night, or tomorrow's early AM commute. :)
Sent from my SM-N910V using Tapatalk
PNWINFERNOPRO
@PNWINFERNOPRO
Full of fuel, washed, waxed, generator checked/run monthly, and her best outfit on. She is just longing for a GPS destination.
PNWINFERNOPRO
@PNWINFERNOPRO
Finished National Luna 60L Twin Compartment Fridge/Freezer install in the F450 camper. Fridge fits near perfectly in the Q-cab; easy access to controls and contents, and removal from the truck, if need be.
Two sides of the airflow vents are completely unobstructed, the rear facing side was blocked by seat back padding. Created an airflow barrier against the seat back padding, using 2 larger polyurethane cutting boards. 1" spacers between the two boards, holes drilled, to keep air moving to the compressor.
Seat back spacing
java
Nicely done! Spacer is slick.
What seat covers are those?
Sent from my SM-G900T using Tapatalk
PNWINFERNOPRO
@PNWINFERNOPRO
Thank you. The cutting boards worked great; clean looking and nice smooth edges.
Coverking seat covers. Perfect fit and top shelf quality.
PNWINFERNOPRO
@PNWINFERNOPRO
Preventative, yearly maintenance taken care of.
220 amp high output alternator installed. Looks like factory, but bumped average voltage output from 13ish to 14.2.
No fun, or impressive pics to show. :(
PNWINFERNOPRO
@PNWINFERNOPRO
New ATish steer tires installed today. Good riding tires and should provide better traction than the previous Continentals.
java
Looking good! Ditch the hub caps! Looks way better (IMO) :D
V45W_Proto2.5
