Coil spring spacers and trailing arm bushings -Mercedes G - W460,461,463
twinge
Good day! I have a G500 shot wheel base! And just yesterday I've installed OME suspension on it, and now I have a vibration from rear shaft!
After removing OME springs from rear axle and installing stock springs vibration disappears at all!
And now I'm looking for "offset (caster correction) bushing set" :) Do You have them?
Thanks!
McBride
Thanks Titus Pullo Suspension (TPS) for your sponsorship of our 2017 rally raid G wagen, again.
We're running the same bushings from last year as they are in perfect condition after last year's race. That's amazing considering that we wore out a set of brand new Fox triple bypass shocks and a set of Fox nitrogen bump stops during the course of the race. The bushings didn't budge.
Here are a couple of pics of your new snorkel installed on the rally G. Wish we had it last year - aspirating saltwater during one of the deep salt water crossings almost cost us the race - the motor almost stalled but amazingly kept on running. This year we'll be better prepared with the higher intake of your military repro snorkel.
Here are a couple of pics. We'll get a couple of more pics once we are on the course.
Again, many thanks for your contribution to our effort.
William
MetalDog
Now available for sale.
Poly coil spring spacer LIFT KITS - 30,40,50 mm. thickness. Combination of different thickness front/rear also available at no additional cost.
Set of 4.
$270 + shipping.
Panhard bar bushings available as well.
Offset Radius arm bushings set available too.
Poly trailing arms bushings, set of 16 - 8 bushings trailing arms to axle, 8 bushing trailing arm to frame.
$280 + shipping.
Contact me here via PM. Worldwide shipping.
Hi Titus, how much for the offset Radius Arm bushings? I'm starting to get a clunk from my front right radius arm, and I'm worried a bushing has started to go out. Thanks.
rpanter
Drivers side (left) snorkel?
Titus,
Do have a snorkel kit for the drivers side (left)? My intake on my 1992 300GE is on the left.
Robert
Goldenbora
