10 lbs C02 System
Stryder106
Since I added an ARB Air Locker, I had to switch to an onboard air compressor and no longer have a need for my C02 system, so it's up for sale. If you don't have onboard air, this is the best way to be able to air down and air up your tires for varying trail conditions. What's included:
* Luxfer 10# C02 Aluminum Tank brush finish - purchased new and still has years to go on it's initial hydro stamp
* C02 specific brass low pressure regulator valve
* Carry handle
* Tank Boot
* Power Tank Power Bracket (for both 10# and 15# cylinders)
* Power Tank Roll Bar Mounts (pair)
*10 Lbs of C02 - the tank is 100% full
$300 for all of it. I'm in SoCal - can't ship the C02 - so pickup only.
XJINTX
I ran my ARB lockers off CO2 and worked like a champ. Just turned CO2 off when not necessary and on road. I forget but had to add a module that ARB sold.
What is that low pressure fitting you have on that? I'm thinking of adding CO2 to my truck and gauges are a PIA. Currently I move my powertank back and forth
Stryder106
Tank/Cylinder Valve is Sherwood CGA-320 (C02 only) valve, Series 4000 regulator (3000psi max) 150 psi. All brass.
oskarf150
