2003 Chevy Suburban 2500 LT build
boss324
I wasn't able to install as I needed the Cognito endlinks that allow clearance for the Rare Parts tie rods last weekend. So Cognito Endlinks SBELKHD-1000 we're ordered and came in yesterday. So first thing this morning the work began. These fit stock height to 3" leveled trucks and SUV's.
Notice how the steering stabilizer has much more clearance. Just got her aligned nice tight and straight! Really happy with these upgrades.
No more worrying about bent tie rods. I also found a busted boot on the right tie rod. Oh and an alignment is a must lol!
Next some new rotors and brakes pads still on the OE pads. Although it still looks like plenty of pad left...so may not tackle that just yet.
Sent from my SAMSUNG-SM-N920A using OB Talk mobile app
Sent from my SAMSUNG-SM-N920A using Tapatalk
fl0w3n
Awesome! How do you like those fox shocks? I had the 5100s on my Duramax and wasn't sure I liked them. I don't have much to compare to though.
I didn't run the front sway bar, I liked the way it rode and handled with out it.
boss324
Love the fox shocks on road and off. Although only other shock I can compare is the Rancho and OE.
rayra
were there specific instructions from cognito to install the end link bottom saddle brackets in that orientation? Because I think you'll find their axis of motion ought to be oriented 90deg from how they sit. So the end links can pivot in a fore and aft direction, in alignment with the vehicle, rather than pivot like the control arms do. As you've pictured them, they appear to me like they'd bind / restrict free motion of the sway bar in relation to the lower control arm. But I might be mistaken.
eta illustration of what I'm trying to convey
The sway bar pivots up and down on the frame brackets. The end describes a shallow vertical arc.
That vertical arc shifts the upper end of the end link rod foreward and rearward on an axis aligned with the length of the vehicle.
In that end link bottom saddle / pivot orientation, there's no pivot action. All the stress is on the weld of the rod to the pivot.
If the saddles are turned 90deg to align their pivot action with that of the sway bar, it should function more properly.
Also by comparison, go look at how the bottom ends of your rear end links are aligned. The axis of rotation. I'm saying the fronts should be oriented the same.
boss324
This pic is before everything was torqed down.
It's hard to install wrong as you won't be able to line up to the steering stabilizer with the endlinks. The endlinks do rotate when tightened so I held the endlinks in place with a cresent wrench while tightening.
The same side finished I included in the post. Oh and the inner tie rod dust boot got all twisted in when installing but just slid off the back on all good.
Watch "Chevy 2500HD Cognito Front HD Sway Bar" on YouTube
https://youtu.be/aib4jgM9PSs
boss324
Some initial feedback since doing the Rare parts and Cognito endlinks. What a difference the new tie rods make. It really does tightened steering with more precision. I used to have slack in the steering wheel; also big bumps used to shudder the front end of the Burb. With the tie rods replaced it feels more solid you do still feel it but the shudder is gone. Stable at high speed one thing I missed on stock setup was the ability to drive 80-85 mph without feeling the vibration and loose floaty feeling from the steering wheel. I am sure I would get this feeling back even if I did new OE tie rods. My setup was worn no doubt due to the 33" tires vs 31 and 116k. It really drives like a new truck.
chilliwak
Glad to hear your truck is running the way you want Boss. Those oversize tie rods are what you need. Post some pics of your fine rig when you get the chance. Cheers, Chilli..:)
boss324
All that work had to give her a good detail this weekend! Thanks Chilli!
RikFlairWoo
Looks great. You really have me considering the the Cognito leveling kit now. You think I would need new front shocks at that point?
boss324
What model/year is your rig. I would do the at minimum the UCA and Bilstein or Fox. Also if you don't add a 1 inch ubolt kit you stance will have that prerunner look (front higher than rear) which didn't look right to me. You can do the suspension upgrades over time like I did. As you need to swap just out for better components.
snowblind
Hey Boss. Looking good.
Did you do idler and pitman arms at the same time? My shop thought they were fine but we had a lot of issues setting alignment and realized that they were worn.
Matt
boss324
Matt
That's next on my radar however they seem fine my alignment is spot on. No more steering play so will wait until I see tire wear then replace with Rare Parts HD pitman/Idler arms. My biggest problem really were worn shocks, endlinks, bumpstops were gone, Cognito PISK brace for leveled ride/bigger tires and bad tie rod.
boss324
It's a 2004 Tahoe 4x4. I recently put the Fox 2.0s on, but they are only made for 0-1" of lift, or so they say.
Ok gotcha well I think your good to go lots other options out there for Tahoe's and 1500 Suburban. Cognito solutions are really geared toward solving GM IFS on 2500 series trucks and SUV, and H2 Hummers. Yes Cognito are spendy but worth it IMO.
https://www.google.com/search?q=200...ndroid-att-us&sourceid=chrome-mobile&ie=UTF-8
abctrash
