AYIAPhoto
Ok, to start, I haven't been here for a while(almost 5 years). I've been super busy working a full+ time job while trying to build a business. I'm at a point where my business is becoming profitable enough to be my sole income and will be able to start enjoying my weekends again:wings:. Anyway, on to my questions...
I've been looking at conversion vans to build out as a travel/light off road(dirt/fire roads, nothing even remotely requiring 4WD)/camping rig. I was looking at conversion vans for the extra headroom without having to go to a pop-top. I just recently came across a '99 E350 school bus with a 7.3PSD. It is a NARROW body(essentially just a squared off body, only a tiny bit wider than a stock E-series), with the single rear tire setup. I sent the seller an E-Mail with some questions and am waiting for a reply. The van appears to have larger tires than stock already installed(looks 265/75/16-ish). The front bumper and rear area of the front fenders look like they have been trimmed to accommodate them. The van however needs some more height, IMHO, to avoid rubbing anywhere but on pavement.
I'm fairly certain that the factory front springs have sagged a bit in the last 18 years, therefore getting it back to stock height before moving on to a lift makes sense. If I can find springs that provide better than stock height, even with the weight of a camper build out inside, all the better. As I understand it, the SD Springs 3935lb "super springs" provide about 1.5 inches of lift on a diesel Econoline. I am however not sure they will maintain that amount of lift once an interior/water system/etc are added to the mix. They also list the TufTruck "Extra Heavy Duty Front Coil Spring" rated at 5000lb that I'm very sure would maintain height, but there is no mention of lift provided leaving me to believe they are merely stiffer at stock height. I'm also concerned that the 5k springs will be rather harsh and seriously limit travel off road.
Concerning spring rates, I am not planning on adding heavy bumpers/a winch or such up front. I am however concerned about "brake dive" once several hundred pounds of interior/water/gear/house batteries are installed. I've worked on and driven these buses for years(be it a long time ago). EMPTY, they tend to have a good bit of nose dive under heavy breaking on the stock springs.
I'm not concerned with alignment at this point, as I can likely dial in camber with ball joint cams at only 2.5". If not, there is a local spring shop that has in the past bent beams to correct alignment when I was still working on these things every day. As to caster, I have stretched radius arms in the past on 2WD Rangers, and fabricated drop brackets for them. The Econoline is just bigger.
So, what says the collective? Try the "super springs" and a small spacer to achieve the desired height, possibly going to a taller spacer if they don't maintain that height with the the interior built out...Or, go straight to the 5k springs and adjust height with spacers as needed.
Oh yeah, the van...
Oh yeah, the van...
