Can someone cut me a FlipPac hinge set (or more)?
As the title says... Can someone cut me a FlipPac hinge set (or more)?
A couple members posted up they could do this.... but have not heard anything more.
I would be interested in buying one or more sets and I bet if you put it out there others would be interested "just in case" as well.
let me know if this is in your capabilities please!
CJS
elcoyote
Supporting Sponsor, Overland Certified OC0004
Be aware that a proper hinge with spines should be heat treated. I suspect that some of the hinge failures reported here on Expo may be due to hinges that were not properly done.
Sent from my SM-G920V using Tapatalk
Good point.... interesting one of the other posts suggested they did some in stainless steel - which I believe is not really heat treatable?...
plh
martensitic stainless steel is hardenable. via heat treatment. 403, 410 etc. Might not have been the alloy that was used.
Arclight
SAR guy
Suggestion: If the splines didn't blow out, you might be able to get a new bit fabricated and welded on. This would get you back on the road. This thing takes a lot of force, so you really want to have a 100% penetration weld done, and control the heat so as not to ruin the treatment on the splined part.
abiker
I just spoke with Brian at Sway Away, who make a replacement torsion bar. They are working on replacement hinges and expect a prototype in about a month.
Barring sway away coming out with hinges, does anyone else have a connection to get some of these made? Or pictures of an install? I'm sure one of us could take the photos and some of the parts to a shop that's willing to make a batch of these.
oskarf150
