2005 F-450 4x4 Utility Body w/ Starcraft Pine Mountain Lonestar Pop-top Camper
PNWINFERNOPRO
@PNWINFERNOPRO
Looking good! Ditch the hub caps! Looks way better (IMO) :D
Sent from my SM-G900T using Tapatalk
I thought about dumping those. I don't really like them at all. Considering the rears as well.
java
I ditched the fronts, left the rears for now.
They are worth something?!?
PNWINFERNOPRO
@PNWINFERNOPRO
When I bought the truck, they said the caps were pricey. They had added them before sale.
I kind of like the look of no front or rear caps. Especially with the service body setup I have.
java
Huh I'll have to look into that! Fronts bothered me because of how far out they stuck
PNWINFERNOPRO
@PNWINFERNOPRO
These happened.
After 12+ years, the original PC1700 camper house batteries are starting to struggle to hold a charge. They had a great life, and experiences from Baja to BC. A small service will be held for immediate family only. :)
PNWINFERNOPRO
@PNWINFERNOPRO
Camper clean-up day, after last trip to BC. Removed the rocker panel decals I had installed a few months ago, as well. Got tired of them.
PNWINFERNOPRO
@PNWINFERNOPRO
House battery power clean-up day:
• I don't have the ability to plug-in to 110 when the truck is parked/stored, so some battery maintenance is needed.
• Started with a slight house battery wiring nest.
• Separated the two batteries' wiring, to test each. Both tested good, just needing a good charge. Have two new batteries that get to stay in house on trickle charge, for awhile. SCORE :)
• Added military style terminals, for easier accessories adds.
• Installed external SAE solar connection, and charge controller, with line splitter to each battery.
• Using a 35w charger/maintainer solar panel, set on the roof. A 2nd panel, temp setup, charges the Odyssey starting battery.
• All working well, with a max charging voltage reading of 13.4v in today's hazy Seattle sun.
It was a good day.
V45W_Proto2.5
