Junkyard requests?
brad2274
Are there any odd gen 2/2.5 parts you guys are in need of? I'm on the search for a local locking diff(im in central FL btw), SR flares (local) and drivers windshield trim piece. But i'm always grabbing other parts i don't need and passing up on others.
Things i grab commonly that i've needed on mine.
-Outside temp sensor
-cruise pump
-early T case lever
-door open sensors
-sun visors
Basically what i'm saying is that i keep buying up some of these parts before the cars get junked, and i'm willing to take some requests of other odd and preferably boxable-size parts youre looking for.
And i currently have some sensors and 2 levers, i thought i trashed my lever but it was something in axle area, message me if you need one ill let them go cheap.
brad2274
Looking for an early Gen2 aux gauge cluster and center grill. :)
i see quite a few grills, can probably get one easy but most have that center mounting tab broken.
and do you need the whole aux gauge pod or the 3 gauges themselves? i think i might have one with a bad inclinometer
Swank Force One
Just the gauges. I have both later styles but i'm really after the old ones with the inclinometer and such, rather than the nearly worthless oil pressure and volt gauges.
PirateMcGee
I could use some detailed pictures of how the factory swing out spare tire on a montero sport works. Especially from the back side of the rear bumper amd inside the rear quarter.
oskarf150
