2008 H3 with a couple of mods (Or/Wa)
BobsCreek
https://bend.craigslist.org/cto/6214867451.html
-ARB bumper with ARB aux lights
-HighLift jack with jack cover mounted to Bull Bar using HighLift mounts.
-Blue Ox towing brackets mounted to where the OEM tow shackles are located. We have two shackles that can attach to the rings on the Blue Ox mounts for recovery
-Warn 8000k winch
-9" high intensity LED dual spots on bumper
-it has a 30 watt Zamp solar panel mounted to the hood where the original plastic fake vent was and was replaced by diamond plate cut to the same pattern to mount the panel. This has a solar controller that leads to the new (last year) AGM battery under the hood. We did this to keep this battery topped of while parked and away from the vehicle whil hiking or whatever while the frig is running.
-we also have a 60 watt folding Overland Solar kit that we use when we are camped. This plugs into an Anderson connector attached to the AGM underhood battery.
-Goal Zero Yeti 400 as second battery. We use this to power the frig at night.
-Whytner 45 qt. refrigerator/freezer with insulated cover
-300 watt inverter mounted in back
-custom built all metal rear fold down tailgate table with molle mount holes with small shovel and ax mounted with Quick Fists
-chuck wagon kit that turns into a table for cooking that has four padded zippered compartments for plates, glasses, cleanup stuff, pots and pans, etc
-two burner propane stove with hose long enough to reach the 5lb propane bottle mounted to the rear rack.
-2 Frontrunner Wolfpacks
-2-Frontrunner folding chairs
-1step stool for accessing the tent
-CVT Mt Shasta roof top tent with Annex and Skylights
-Mr Heater portable propane heater with custom made bracket to mount the heater inside the tent. Attaches to the tent structure using Quick Fists and propane hose runs into tent from the propane bottle on the rear rack
-Scangauge on dash
-OEM Pioneer Bluetooth sound system with GPS
-two 12v dash outlets with one dual USB adapter
-all interior lights switched to LED to conserve power
-Weathertech floor matts
-Coverking canvas seat covers
-Kenwood TM-281 2 meter ham radio mounted to passenger side of trans hump with Mag antenna on roof
-Midland CB radio with Firestik antenna mounted to bumper
-RAINGLER webbing barrier installed
-behind front seats
-bow saw
-machete
-fire extinguisher mounted in rear.
-Frontrunner 5 gal Jerry can for water with brass faucet
-bin organizers for : air compressor, HighLift Jack base and accessories, bottle Jack, ARB tire deflator, recovery straps, tow straps,tire repair kit, magnetic LED light that attach anywhere outside for evening camp use.
-Tepui 6' Awning mounted to passenger side
-Rhino roof rack
-custom made rear carrier rack that mounts to the spare wheel on rear door that carrys:
Tred recovery treads
Leveler blocks for level camping
5 pound propane tank (securely mounted)
Trash barrel
2 gal Rotopax gas
5 gal NATO gas can without the fussy "safety" spout in a lockable holder
-rock sliders
shmabs
This is a very nice setup and seems to be well built, I've seen it in person and was quite impressed.
To the OP,
This is mike, we met in eastern Oregon on the way to the NWOR, my son and I were driving the maroon land cruiser. Good luck with the sale! What's next?
