Cruse Control Woes
Have a 97 SR that the cruse control does not work on. When I press the button the light does not come on as if it is not getting any power. Anybody done any trouble shooting on these systems? I cant find anything on it in my service manual, thought maybe someone here could point me in the right direction.
Thanks in advance,
MKR
brad2274
the fsm has a section testing the switch near the bottom, i think its not listed in table of contents. i've had my system fail 3 times but it's always been the pump. there should be a control unit in front passenger kick panel area. If i were you i would hit up the pull n pay yards and just buy some switches and control unit, try swapping parts as theyll be very cheap. That's what i've been doing with success. I have some spare control switches but i'll have to check if i got any cruise master switches.
Thanks for the info, brad2274. If I can find one in a junk yard around here I'll try that. Do you know if the same unit is used in the Sports?
MKR
brad2274
MKR
based on oem part sites, it might not be, has a different part number even though the system looks the same and they shared motors.
http://www.mitsubishipartswarehouse.com/mitsubishi/montero/mr159576/1995-year/ls-trim/3-0l-v6-gas-engine/electrical-cat/cruise-control-system-scat/?part_name=control-module
But you should be able to use any montero unit from 1994-2000
again i dont know if this is your issue but its one way to go about diagnosing it. i would still check for power first, refer to FSM
http://www.ebay.com/itm/MITSUBISHI-MONTERO-CRUISE-CONTROL-MODULE-MR159576-/222206969021
