Free Stuff from Cleaning Out Storage
TheMole
Sold my Montero a little while ago and just got around to checking which parts I have leftover. The following items are free for pickup in the Los Angeles area. Will add more stuff as I come across them.
Available
Moog idler arm - used, but still tight
(2) 265/70/15 BF Goodrich longtrail? - still have some usable tread
Pending
Gone
OEM radiator cap - barely used
OEM idler arm - used original, but can be rebuilt
Fel-pro MS95709 intake manifold gaskets - new, but does not include lower manifold and egr gaskets
Fel-pro 60879 throttle body gasket - new
Moog K90631 rear swaybar bushings - new, should double check fitment
Moog K90635 front swaybar bushings - new, should double check fitment
Metra 70-7001 Mitsubishi 92+ stereo install harness - new, believe it should fit cars without factory amp
OEM MN176208 rear cam o-ring - new
OEM radiator - needs rebuild as it leaks
CSF radiator - needs rebuild as it leaks
I'd take the bushings if still available, the radiator cap and MOOG idler arm. I'm in LA so let me know what works schedule wise. Thanks Mole.
kalieracer
I will take the radiators.
TheMole
Still have the following available.
TheMole
Still have these will probably be going in the trash soon.
DanoWall
