My 2014 Phoenix camper came with PEX plumbing and it was pretty good but I did have a few small leaks (especially following extreme rough 'roads') - the bigger problem is that is impossible to modify - 1) once assembled the PEX plastic forms over the connector making very difficult to take apart 2) the tube isn't very flexible in the first place and after being installed a year the 'shape' is permanent. So it unlikely that you'll be able to re-use the 'hose'.
At Expo I noticed the big boys were using flexible Reinforced PVC Braided Tubing and I thought 'genius' this tube is readily modified:
https://smile.amazon.com/HydroMaxx-Flexible-Pressure-Reinforced-1531012050/dp/B01BCJZ5ZM
Unfortunately, I didn't pay enough attention and connectors I bought frequently leak and the hose clamps often come loose or worse break.
I used sharkbite and these just do not create a permanent seal: https://smile.amazon.com/gp/product/B007AHGMJO/
Anyone have a recommendation for good connectors for PVC tubing?
this one looks good and is nicely barbed
https://smile.amazon.com/LTWFITTING-Brass-Barb-Fitting-Water/dp/B00CHI0YUY/
I've used connectors from parker for other purpose so these might be good:
https://smile.amazon.com/Parker-224-8-8-6-Union-0-375-Barbed/dp/B0078RSR7G/
TIA,
TIA,
