1990 Mercedes 917 4X4 with Custom 15' XPCube with clean US title, Located: California
UpperCrust
Building and Learning
IMG_9143 Cube sm by casejeep
Truck Base
1990 Mercedes 917 4x4 ex German fire truck with full USA/ Arizona registration and title
30,000 km
12MPG
5 speed Front and rear lockers
5 new MPT81 tires on beadlock split rims
16,500lbs Come-Up Front winch and rear winch
Torsion free 3 point sub-frame
12 v to 24 volt conversion
LED driving lights
LED light bar
60 gallon fuel tank
Heat and Sound insulation
Ample aluminum under body storage units
Spare tire winch
Master craft seats with 3 point harness
Rear bumper pivots up for extra clearance
IMG_9007 by casejeep
IMG_9020 by casejeep
XPCamper Camper Construction with Full Factory Warranty
Monocoque foam core
Exterior color - white
Aluminum corner guards
Composite doors with all matching key locks
Interior color - white
Interior Finishes
Mahogany wood trim
Vinyl marine teak and ebony floor with real teak trim
Cabinet hardware (push button, positive locking hardware)
IMG_9184 int by casejeep
Power Supply
3 solar panels @ 160W ea. (480 total) w/30 amp controller
4 batteries @ 300 AH AGM 6V ea. (600 amp 12V)
Marine grade wires and connectors with ID tags
Marine Breaker 360 - Blue Sea Systems/main shut off switch
Charge system (charging system for camper batteries from truck)
6 x 120v outlets (bed, kitchen and dinette, storage)
4 x 12v outlets (bed, kitchen and dinette, storage)
4 x double USB outlets (bed, kitchen and dinette, storage)
2000w Magnum pure sine inverter w/30 amp charger + battery monitoring system
30 amp SmartPlug with 25 ft cable
IMG_4573 by casejeep
IMG_4555 by casejeep
Kitchen
Formica countertop with water catch in black
Flip up counter top
Single handle stainless faucet with ceramic valve and spray handle
Hands-free electric operated water delivery system
Stainless steel sink
2-way fan over galley
Overhead cabinet with LED under mount lights
All stainless steel hardware
7 Storage drawers with ball bearing sliders in cabin
7.3 cu.ft. (130l) 12V compressor marine fridge with freezer
Diesel cooktop x100 by Webasto
Microwave/convection oven
Large cabinet under sink
9084 Kitchen by casejeep
9093 Fridge micro by casejeep
9066 Hanging storage by casejeep
9087 Kitchen control panel by casejeep
9069 Kitchen upper by casejeep
9085 Kitchen under sink by casejeep
IMG_4574 by casejeep
Main Cabin
High grade foam for seats with Sunbrella fabric
3 stage telescoping table - converts to bed
Marine hardware for all hinges and latches
Heat outlets in main cabin and storage area
4 LED lights
2 LED reading lights
Overhead storage compartments
Hanging closet
Pantry Shoe storage
IMG_4548 by casejeep
IMG_4549 by casejeep
IMG_4579 by casejeep
IMG_4559 by casejeep
Bathroom
Cassette toilet C402
Single handle stainless shower faucet with ceramic valve
Fan to vent bathroom
LED light
Toilet paper holder (waterproof)
Retractable clothing line
Teak grate
Shower caddy holder
IMG_4554 by casejeep
IMG_4553 by casejeep
Bed Area
Under bed storage with custom storage bags 2x
Gooseneck LED reading light in bed area
High grade foam and Sunbrella fabric for mattress
Large storage compartment with charging station
European spring mattress system from Froli
Storage cabinets above bed
Large operable skylight with lights, mosquito netting and sunshades
IMG_4564 by casejeep
9095 Under seat storage by casejeep
9094 Seat back storage by casejeep
Windows
All windows with built-in shades and mosquito netting
2 reversible fans in ceiling
Skylight over bed
Water System
80 gallon heated fresh water tank with gravity fill
23 gallon grey water tank with gravity drain
Johnson water pump with prefilter
Sump pump for grey water
Webasto Dual Top diesel water/air heater
Digital water gauge to monitor tanks
All marine grade hoses with SS “v” hose clamps
Water filtration system
Stainless steel outside shower
Stainless steel lockable water fill
9107 Ext Shower by casejeep
Lights
6 LED lights in main cabin
LED under cabinet light in kitchen area
LED outside and inside entryway
LED lights in storage area
9108 Rear cargo close by casejeep
Other
24” 12volt LED TV/DVD
Dometic 6ft. self-supporting awning with LED lights
Price: $195,000 USD
Or Best Offer
Contact:
Case or Christina
(928) 699-5931
(928) 551-0529
Crew@uppercrustexpeditions.com
cleansweep
Nice Rig,
What size engine and how fast can it cruise comfortably?
Is it a fresh build btw?
Could you shed some light on why you are selling it ?
Thanks!
UpperCrust
Its a 6 cylinder Mercedes engine and can go about 65 comfortably. It is a brand new camper, only been used to transport to Overland Expo. We had twins so unfortunately there isnt enough room for our whole family.
ChuckB
Congrats on the twins!
Thank you for answering my question on if the family will fit. Looks like a solid no. I have twins also and a third child.
GLWS, nice rig!
Mattersnots
Dimensions
Very cool truck. Good job on the write up, I could take a few pointers.
Just a few more questions.
What are the overall outside dimensions?
Would two bicycles fit under the bed? Can you give me measurements of the openings and rear storage area.
How about some pictures of the inside of the cab.
Thank you.
Racingdad
I would think 2 adults and two children would have more than enough room so I assume there are more than four in your family. That dinette looks large enough for 2 adults to sleep on comfortably. Very nice example of a XP Camper cube. Can you provide pictures with a bit wider angle to see more?
GLWS
Tad
chp-sk8
Spent a lot of time in the rig during the built at XP. This is all top shelf with zero short cuts. All of the systems and functionality are spot on with nothing left unturned. Top shelf rig from a legit guy. All the best my friend.
Eli
Nimbl Vehicles
Freedom to Roam
I would think 2 adults and two children would have more than enough room so I assume there are more than four in your family. That dinette looks large enough for 2 adults to sleep on comfortably. Very nice example of a XPCamper cube. Can you provide pictures with a bit wider angle to see more?
GLWS
Tad
Here is a 360 View.
https://www.facebook.com/XPCamper/p...569615604637/1564521930242725/?type=3&theater
https://www.facebook.com/XPCamper/p...569615604637/1564487553579496/?type=3&theater
Keyne
Bump for a great truck. GLWS
Also, just wondering per the question above. What are the exterior dimensions (e.g. total length and height)?
UpperCrust
20' long and 10.6' high and 8' wide. Has a turning radius better than a Tacoma.
Keyne
Wow only 20' long and around 10' high it is basically the same dimensions as my 144 Sprinter. That's an awesome size and proves why I love cabovers; max space for length.
