2004 Tundra Adventure Cab - Build/Adventure Thread
toyotech
toyotech
Going to moab again this year. Taco rock therapy or roctober is in October this year. Hoping for cooler weather and less bugs. I been slowly changing things up for this trip.
First I have always wanted to bypass the internal transcooler in the radiator so I picked up and external one to work inline with the factory external one. Added a fan mainly for radiator temps when crawling with the AC during hot summers.
Also changed the speakers with some Polk audio. So far they are loud and crisp sounding. Also added a little sound deadener behind them as well.
trailscape
How's the durability of that cooler look? I'm trying to decide if the B&M version is worth the extra coin for the stacked plate design. Rocks seem to do a number on the fin design.
toyotech
Looks and feels like a nice unit. Very basic. Nothing fancy. Similar to the condenser. It's in a low pressure use so I don't see any issues in the near future. Everything behind the grill doesn't see rocks.
trailscape
Mine looks like it's been taking a beating. Interested to hear about any temp drops.
toyotech
You can fix those Fins. Also look into a mesh screen behind your grill to help with rocks.
toyotech
I've pulled those out more times than I ever care to
First time ever on a tundra. First time ever for the front diff. What the heck is the trick. I had to remove the two bolts on the front diff rear rubber mount to get it out. I originally removed the 12mm hex but you can't lift the diff high enough to get it pass the cross member
gp01
