TaTundra 1 gen DC build
theBullfrog125
The canvas on the rack looks cool! Does it flap around like crazy on the highway? I've been contemplating making my own soft topper of sorts almost identical to what you have done. I like my fiberglass shell but it's a lot of weight.
tyv12
Ya gonna tear it down and see...
Actually the cover is a heavy fabric that I've got strung with parachute wire and it doesn't flap at all I'm pretty happy with it gives good shade for the doge and I can still reach stuff out of the front of the box
tyv12
It was already built but I had to swap the pinion flange and from what I've read this noise is a preload problem but I'm not taking chances and I'm gone take it apart and check everything
toyotech
Did you count the turns on the nut before removing so it went back the same?
tyv12
Yes I did but it was a different flange so u I don't know if that made a difference
tyv12
Got it all apart, definitely the pinion bearings they were almost binding when preloaded, the races are a mess, not sure what happened but gonna replace them and put in a crush sleeve eliminator maybe I screwed something when I changed flanges... I'm really sick of pulling this apart
toyotech
Yeah if you changed flanges than it's almost impossible to put the nut back on the same to maintain correct preload
RockenAlex
So you're over-geared with 35's and 4.56's? I was under the impression that they would be a hair under geared... I was thinking I would need 4.88's when I go to 37's but seems like I may need to go with 4.56's based on what I've been reading recently... ('06 DC)
tyv12
I did the calculations and 4.56 is slightly overgeared, to be identical to stock it would have been 4.52
https://tiresize.com/gear-ratio-calculator/
This is the gear calculator I used
But the extra rolling resistance and that with the big tires I'm thinking 37s ur gonna want 4.88s
toyotech
Why would you want to regear back to stock specs? Stock specs is rated for a stock weight vehicle. When you start to increase weight. You want to be over geared imo
tyv12
Yes i agree, the 4.56 work well for me with a 5 speed tranny, it's a balance between torque from low gearing and how high you want the rpms you want on the highway
jsnow
I have a 2001 Tundra with 35's and I am running 4.88's. My opinion is 4.56 would have been just about right, but I traded off some hwy performance for off-road performance. I don't regret 4.88's for one second.
Henrybrowne
