Having trouble with CS130D not charging after hooking up isolator, help!
DiploStrat
Not Quite Crazy ...
But close enough.
I have always understood dual diode isolators to work like this:
Some, like yours, allow you to reach around the diode with a sense wire, thus allowing the alternator to run at a higher voltage to compensate for the loss. As you noted, some alternators have to see voltage at their output terminal in order to turn on. I am not sure of how to solve this problem with a diode system. (Some Sterling Power products, which also use diodes, but for other purposes, have a bypass terminal to allow battery voltage to appear at the alternator output terminal.) dwh knows what he writes about and I would consider his counsel carefully.
As I have noted, I simply prefer other solutions to the problem.
Happy wiring!
Meili
I think your diodes are facing the wrong way!
I did stop at the local auto electic shop, yes the charge terminal needs to see voltage.
Most likely going to do the soleniod thing to make my life simpler.
DiploStrat
I cut and pasted the diagram from the Internet. We History majors don't know nutin' 'bout electrical diagrams.
I have a ton of material about camper electrics on my website, or, if you prefer, you can come harass me at OEXPO East.
All the best!
seth.c96
