100 Series Cargo Dimensions??
davej
Are these 100 series cargo dimensions correct?
Can someone tell me what the cargo floor depth to the tucked 2nd row seats would be?
And what the depth would be with the 2nd row seats removed?
Thanks...I'm planning on buying my 1st Hundy soon and would like some extra info (I've owned a '40 for over 20 yrs).
Chris Boyd
In that case, I guess I'll put up or shut up ;)
I don't have my second row out on either of my trucks. Here is the 2006 DD info.
I'll try to get the second row approximation with my truck that has drawers. On that the drawer tops and once folded 2nd row are basically flush. So I can pull that measurement.
I sleep on that configuration and it's at least 6'-3" which is how tall I am.
davej
That is very, very helpful. Thank you. If you're able to get that measurement all the way to the first row seats, that would really be helpful too.
The reason I'm trying to get such specific numbers before buying (which will probably involve flying to Tx or Fla since I live in Michigan)..is because I own a photobooth rental company and I'd really like to be able to transport my booth in the Hundy (in addition to having an awesome camping/expo vehicle). But the measurements will be really close. Lying on it's side, my booth will stretch 74.5" deep into the cargo area...and be 38" high. That 38" is probably just a smidge too tall...but I should be able to reconfigure things drop that number to 35" or 36".
Thanks again.
4Beast
Thanks again.
Well, if you were able to take out the third row and turn the "high" into "wide" it is something like 42" between wheel wells, depending on whether or not you count the "hump"... Not sure if that helps
Chris Boyd
I was able to get the other rig out today (a '99). Like I said in the thread earlier, this is with the second row folded once and not tumbled forward. My drawers are roughly the same height as the second row folded (as you can see).
Also included a photo of the most narrow entry point at the rear door. My drawers are taller than the wheel wells, so that would be the limiting dimension.
Chris Boyd
BTW, this is with both front seats slid fully back, with average recline. Like I said, I'm 6-3" so if you're not, there might be extra with the seats slid forward.
gp01
