JK mud flaps
One of the biggest complaints I have had in my JK when towing or even using a cargo carrier is the amount of stuff the tires kick up. I have tried my own home made solutions and they all looked hideous and worked marginally. Couple months ago while getting some replacement parts for my suspension lift I saw these on terraflex’s web site. Ordered them and they have worked out way above expectations so wanted to share. I get asked about these all the time but have not seen much info on them. Tires in my JK are 35”. Easily adjustable, and extremely simple to install. They also remove in a couple seconds by twisting the outer nut with only the mounting plate staying in the Jeep. Took about 5 minutes to install as well
bde76a2be746a7c18f5edee4c7884c40.heic
f840c4dad69347e848a1ab20de950264.heic
b43847d9a504e5a96612922c7857f8fa.heic
ceb0e288cb1b2f6d6fa5e05cf27a457e.heic
fc0b79eeaa0e79b6c9b590475b518b72.heic
44c087e7bb706568f964e95a6194a46a.heic
Crunch337
I like it! I'm going to get the AEV flaps that go with their bumper, and the Mopar flaps for the front. Hopefully this makes a difference this winter. They'll come off in the Spring.... probably.
slvyj
I have that setup. You have to drill your front fenders to mount the Mopar flaps. I also have a rust issue with the AEV bumper so now I can't remove the AEV flaps.
BADDANDY
I have the stock flaps mounted in the stock position on the front, but modified stock rear to fit my rear Smittybilt bumper. They sit higher, I heat bended them back for tire clearance, and made a little filler piece.
Dan Grec
I have the stock Mopar ones on the front - and while they do a good job of keeping most mud off the doors, they are probably more trouble than they are worth.
Every time they snag on a rock or a log they pull back on the entire (stock) fender, tearing it.
I have torn one in half, and the other almost right off.
So far gorilla tape and zip ties are keeping the fenders and mud flaps on, but it's not a long-term solution.
-Dan
Outside somewhere
Overland certified public figure brand ambassador
Have the aev's and have not been kind to them. Have had 2-3" tree branches wedged between them the fender and the tire and they haven't been damaged yet.
