rcharrette
Hi all, I've had my LR3 for almost 6 years now and it has 190K miles on it. I've been using lift rods for all those years as well, installing and removing as needed. Last month when removing one of the rear rods I finally did it, I snapped the plastic arm on the sensor. Anyway, for a number of reasons (no rods, diag, repairs, etc) I've been considering the GAP tool with BT.
I was about to pull the trigger this morning when I noticed the "fine print" at the bottom of the page that says firmware upgrades are free for the first year then 500GPB (about $650) after that. Do most of you not update your tool?
Also, since my truck is getting up there in age I may move over to an LR4 in the future. Will it be possible to "reset" the tool and use it on a newer LR4 (say 2015ish)?
Thanks for the help!
I just read a bit closer and it looks like updates are just for the Pro version I guess. So scratch question one unless I'm misunderstanding.
