LT230 Transfer Case Question
MBurzon
Photo/Video, Mechanic, Cook, Driver, First Aid
Has anybody seen an LT230 transfer case where forward is high range and back is low range? How could this be?
rlynch356
Defyota
the Hi/Low range is on a separate gear. you have to move the shift fork to engage it.
Here is the diagram
Red90
The arm on the lever shaft can be flipped to make it work backwards. Here are a couple of correct arrangments. It varies with the gearbox and in most cases, you can get it to work reversed.
Ancientsojourners
