Has anyone looked at running the MRAP 20x10 wheels with an adapter?
Any thoughts?
I have MRAP wheels
(Atlas) on my MB1017AF and also own a '02 Fuso FG with super singles, and there is no way MRAP wheels will work on the FG.
1. They have a 100% offset (11-11.25" backspacing), so they will not be close to running in the same track when reversed. About 13+ inches off.
2. Unless you find the Unicorn of MRAP wheels, NSN 2530-01-479-2916, none of them will work reversed. All of the others have a step in the rim so they can not be mounted reversed on the rear,
(although maybe you could counter that when you build your adapter?). Also, some have a built-in regulator that would interfer with reverse mounting.
3. The Atlas rims that will work reversed (but they have to be 'assembled' that way, so not flippable in the field), are about as easy to find as a 2007 Fuso FG with <10,000 miles.
4. If you order wheels from Hutchinson, they will cost about as much as a 2007 Fuso FG with <10,000 miles.
5. They have a huge load rating, about what a Fuso weights per wheel, so overkill and the related weight that goes with that. The steel wheels that are 50/50 offset would be a closer option (but still way off), I'm guessing from the 1/2 that I have, weight just under 100 lbs per wheel (then add in your adapter).
6. MRAP wheels are hub-centric, not stud-centric.
There is a thread over on
Steel Soldier  https://www.steelsoldiers.com/showthread.php?84241-Combat-wheels-FMTV-wheels-HEMTT-wheels that has diagrams of all of the military wheels. You need to be signed in to view attachements at the website.
click to enlarge
