it will be a standlone system bluetoothed to a tablet.
I have a 2m/70cm that is my primary.
Ok, thanks for your thoughts.
I am thinking I could bluetooth this to a laptop/netbook that has an APRS client that uses KISS TNC protocol too.
this will be a linux laptop. havent used windows in about 10 years. and that is why I'd love gaia gps to integrate aprsdroid.
I run a Mobilinkd connected to a Yaesu FTM-3100R and it works well.
When I move it over to the Jeep I am building I too will wire it similar to your description above.
I had go make my own cable to plug into the mic jack and the external speaker jack of the radio but it was not hard at all, Mobilinkd sells the TRRS plugs on their website. I started out trying to use a cheap HT with an external antenna for APRS but got tired of jacking with it, poor receive, and barely making it to the nearest digipeater (20+ miles away). Works much better now and can work APRS packet through the ISS with the same mobile set up.
Sorry I can help you specifically with the Maxtrac or Gaia integration.
Any issues with desensing your other 2m mobile (assuming you have one, maybe you dont)?
I have had some people bring this concern up. I definitely dont want to damage my 2m/70cm mobile (an Icom 2730A)
We're you thinking of a Raspberry PI for something? You can run Xastir on Linux. I also have compiled Xastir for my Mac, so that's what I use at the home QTH. Is APRSISCE32 still in active development? Anyway, I wonder if it would be possible to get Xastir running on iOS? I don't know either way but my suspicion is no, I'm using Macports and the XQuartz framework for Xastir, it's not a native OS X app as such.I know guys are doing that with windows tablets running APRSISCE32.
Had considered doing what this guy did with a Windows tablet and his Yeasu FTM-400XDR (what I run)... I have a hard time ditching GaiaGPS on my iPad though, and 2 tablets seems excessive...
I had a dual band and an APRS antenna on the roof of my old truck. Even at 5W with them that close it was what I'd call crazy de-sense. I was worried I would ruin the front end of my radio, S9+ even on different bands (e.g. if I was using UHF it would blow out). I ended up buying an FTM-350 to integrate phone and APRS as a hasty solution. In the new truck I'm putting the APRS on a stubby antenna on the bull bar with the regular dual band probably on the roof.After my project XJ is built both 2m and APRS antennas will be on the roof so I may have more of an issue then, we shall see.
The only thing that still eludes me is combining high quality navigation with APRS without using Backcountry Navigator (which isn't interesting to me because I don't want to be constrained to Android). I've had limited (as in next to zero) success with getting Navit to work but even if I did integrating it with Xastir would still be necessary I guess. Underlying a decent map in Xastir is fine when you're just interested in see where you are and your position relative to other APRS stations, though.
FWIW, I don't find it difficult to get maps for Xastir. I've been able to generate configuration files to pull down online data from nationalmap.gov for both topo and aerial data. You can cache them, too, or regular offline is just a matter of downloading tons of large files and sticking them in the shared directory.
