Project #3 - Custom outfitted Overland Trailer
JJBiggs
Supporting Sponsor | SEES
Howdy folks...
Been quite a while since I last posted a trailer project. The first being a small M416 style cargo trailer with a RTT on it. The next - The Terrapod ONE prototype. The latest from my shop - A fully custom outfitted CVT off road trailer.
Features:
Custom designed / CNC aluminum RTT rack
Custom designed aluminum fridge / electrical enclosure
Upgrade LED lighting (bin and exterior floods)
Added backup LED flood
Custom designed modular onboard water system
Custom dual charge electrical system with LiFePo4 battery
Modified solar charing system
Custom designed gas spring assisted awning lift
Side mounted stowable table
Custom spare tire mount (in work)
Purchased / Installed items:
CVT Off Road Trailer
Tepui Kukenam RTT
Rhino Rack Foxwing Eco
Indel B 41qt Fridge
LED mini's rock lights & spots
50Ah EWS LiFePo4 battery (with internal BMS)
LiFePo4 compatible Bioenno Power charge controller
Powertank 5lb propane mount
5b propane bottle (w/ extension line)
Renogy portable 100w solar panel
2x Scepter water cans
Rigid mini LED's
Tongue mounted bubble level
a few more misc items coming...
Been a fun project. Particularly the challenge of developing the electrical system to handle charging the LiFePo4 battery. Looking forward to getting it out there and testing. If anyone is interested in a custom executed off road trailer, contact me. I'd love to build one for you.
Cheers,
C
Photos:
JJBiggs
Thank you.
For the most part, yes. A couple items I had to get cut on a waterjet system. All design and assembly work - me.
C
ratled
WOW, a very nice job. I'm really crushing on the dog house for fridge, a custom fab too?
ratled
ratled
How are you doing the venting for when the fridge is running and the door is closed
Thanks
Ratled
JJBiggs
Thanks
Ratled
There are two 4x10" vents located in between each side. They are marine style vents that will allow for air flow but keep water out. I am about to add some light foam filters to them to help keep the dust out as well.
C
Henrybrowne
