IncorpoRatedX
Vehicle: 1999 Montero with locker.
Goldi-locker was purchased in LA quite a while back to fill the montero void in our life...
After 2 years of moderate to heavy use for a stock truck, it has held up great. Recently I installed a new denso alternator, new trans lines, added new fluid and put in a fresh-from-the-dealer coolant reservoir. Then stabbed four new Bilstein 5100 long travel shocks and stainless skidplates, total shock install took about two hours, 30 minutes each, I didn't take any of my wheels off and only used a floor jack and some hand tools.
The real trick to installing these long travel shocks is a good long wood working clamp, safety protection of course, and some strong string. I used the wood clamp to compress the shocks, tied them off with the string and popped them in. The trick to removing the stock shocks was to tie them off with the vehicle at rest, then jack the truck up and undo the bolts, they remain compressed and slip out nice and easy. The skids bolted up to the stock location so no real thought was needed here, i dropped the old flimsy stamped mild-steel units and replaced them with some super robust 10 gauge stainless formed pieces...
Saturday after the install I went out with the local crew to some rocky trails, the 5100's ride very plush, they soak up terrain and make washboard roads feel like mall parking lots. I was so impressed with the quality of the ride, i decided I wouldnt air down my tires so I could see just how nice the Bilstein 5100 is compared to a KYB... I did the same trail a year prior with the same truck on KYB's and it beat the heck out of me, I even aired down on that run...
The whole day went smooth, the ride was good with the tires at full pressure, but the trail kept getting rockier and rockier, at one point as we casually strolled through a rubble road I said to myself, or maybe to my co-pilot CJ "I think I should air down" - but we were almost to the secret lake, so whatever, I'll be fine, the exit is right after the lake anyho-PSSSSH 'oh no, is that us? That's us!" PSSSSH rear tire encountered a very sharp knife edged rock with the sidewall. My tires are Yokohama Geolander A/T-S in 31x10.50R15 on some 15x8 turbine wheels, perfect for a stock truck, especially a gen 2.5 with 4.27 gears... After swapping on the spare I caught back up with the gang and it was decided, Ive got the front 4.90's, the rears will be here soon, it's time for 33's...
