Spares
krick3tt
Thinking of a road trip this fall. What spares would you recommend I carry (not a spare LR, already thought of that) for possible issues. The LR is/has recently been gone over but I am gathering the things that might cause concern far from home or a LR facility. Have ordered a new alternator and am having new plugs installed (130K miles, probably the same plugs it came with). It is a 2nd owner vehicle but many things are new on it now. I have things fixed as they come up and don't wait till it won't move to repair things.
Tales of issues you have had are welcome.
azarmadillo
Would help to know what model. If it's a RRC or D1 I would suggest fuel pump, all belts, alternator and a bag of relays and an ECU.
krick3tt
Thanks for bringing that up.
Did I leave out pertinent info? Guess so. 2007 LR3 HSE 4.4L V8 w/ 130K+ miles.
Serviced at 116K w/ F&R (locking) diff. & Xfer case oil service, brake flush, new air compressor (LR4), new L & R lower control arms, new tie rod ends, oil service every 5K miles since then, new water pump. New crosslink valve, New sway bar bushings rear. Hoses inspected and found OK.
New brake rotors and pads @ 127K miles. Removed TPMS as new tires installed on steel rims. Removed F & R distance sensors because ARB front and Tech 4X rear bumper installed (without them). New temp cont valve and heads R&R to be machined due to warping, done at 117K miles (poor service from PO).
I am trying to keep this thing in good order but things do come up now and then. I carry a spare belt. (This is left over from owning many VW autos previously).
Happy trails
DiscoDavis
Happy trails
IID tool
Fan belt
Fan nut/pulley wrenches
oil filter
13mm socket/wrench minimum
air filter
PCV
bleeder T or brass straight barbed fitting (nobody needs the T)
3lb hammer
7/8 socket and 1/2 bar for lugs
spark plug socket
torx bits for various hoses, fittings
brake light switch
some bulbs
krick3tt
Thanks.
IID tool--got it
Fan belt--got it
Fan nut/pulley wrenches-need, not sure where to source
oil filter--got it
13mm socket/wrench minimum--got it, complete socket set
air filter--got it
PCV-need
bleeder T or brass straight barbed fitting (nobody needs the T)--got it, not installed yet
3lb hammer--got it (actually 2lb for tent stakes)
7/8 socket and 1/2 bar for lugs--got it, always in vehicle
spark plug socket-need
torx bits for various hoses, fittings--got it, complete set
brake light switch-need (just ordered from Amazon for $15, free shipping)
some bulbs-need
krick3tt
I tried the LED bulbs for the tail lights/flashers but they flash rapidly and that is not good. took them out and put the incandescents back in. Still have the LED bulbs. I was told that my LR has some kind of voltage issue with LED bulbs, a design sort of thing.
DiscoDavis
If the LED bulbs do not have ballast built into them to correct for the incandescent setup they will have issues.
454
Exploder
Stick with OEM bulbs for the brake lights.
Stick with bulbs, a brake switch, and a IId tool. If the truck is regularly maintained, you don't need a box full of spares.
Have the alternator and battery tested.
Ray_G
^This.
krick3tt
Thanks for the information and suggestions.
I have ordered an extra set of bulbs (front, rear) to keep on hand for possible outages. The ARB bumper may create issues in removing the front light assembly for refitting the bulbs, its just a bit of maneuvering to free the assembly but it can be done.
krick3tt
OK, lots of info but no opinions on fuses?
This vehicle is apparently dependent on electronics and every circuit has fuses. What are the most common and probably needed?
I am having the plugs changed this weekend.
DiscoDavis
Why not just buy a box of assorted fuses.
DiscoDavis
You will need to remove the ARB bar in order to get the headlamp assembly out. Some say its possible without removing the bar but I have not seen it done. You're gonna get very handy with a set of 18mm wrenches and hope you've got baby hands and wrists
DanoWall
