Rotopax like sand ladder?
02rangeredge
would you use them only when you'd emptied them? because empty they'd be much weaker, but if you filled them with fuel your fairly likely to spill gasoline across the ground
JDaPP
That was my thought as well which is why I was wondering if anyone had used them.Would be nice if you could use water (says okay for non potable). Also curious what they did to make it strong enough to drive on it? Is it stronger than rotopax?
roving1
This is the dumbest idea ever short of a last ditch effort. Looks like it would take all of 5 seconds to break the filler cap or vent.
BritKLR
Kapitis Indagatoris
Boooommm......as fuel vapors are forced out under pressure and ignite, not to mention the liquid fuel...I guess that's one way to get your truck out of the sand.
Airmapper
Inactive Member
Put something under each end and it would probably make a real nice bench to sit next to the campfire as well....
