Wildernest Outrigger pole hardware?
Jmax
Hey y'all
I'd like to install outrigger poles onto my Nest to prevent it from bouncing and rocking. Unfortunately I can't use a hi lift for this purpose, and my nest came without the necessary hardware.
Anyone have some close up pictures of the outrigger pole hardware? Would be very helpful!
Thanks
J
DaveInDenver
Middle Income Semi-Redneck
Nothing special. Two telescoping lengths, the top was swaged to fit the bracket on the lid and they originally had a plastic thumb screw on what's otherwise just a hose clamp.
Clutch
<---Pass
You can get quick adjust tent poles from Cabelas or similar. Are you missing the angle aluminum pieces that are on the shell itself too?
LINK
Jmax
Any pictures of the original bracket on the shell that these poles attach to? Again, thank you!
Clutch
<---Pass
Welcome!
Nothing special...guess I keep on forgetting to replace the hardware with stainless, doh! I put stainless hinges on though.
Here is a link to some part numbers: http://forum.expeditionportal.com/archive/index.php/t-4338.html
scojo1
I made mine by cutting a 10' length of thick walled aluminum pipe in half and threading the 2 plain ends.
Then screwed steel pipe caps on one end of both pipes. Drill and tap the caps to accommodate 3/8 threaded rod.
Cut a couple pieces of threaded rod(I made mine about 18" each)and screw into the cap. Thread a nut down for a lock nut,
then add 2 more to each. One for below the bracket and one for above. Screw a couple of flanges for feet on the other end and your done.
project13support
