40 Guy builds a 100 Series
Rezarf <><
Decided to get serious about adding a switch panel. Contura rockers off eBay and a little time with the box knife and I ended up with this set up.
Before...
img_2420-jpg.1637077
Cut, chop, rebuild...
img_3045-jpg.1637079
Done...
img_3048-jpg.1637081
Rezarf <><
Looks nice. I like the ceiling rack.
Thanks man, I have loved your threads in the past. Thanks for the kind words.
Twenty pages in....and I'm still hungry for more. How did the LED light bar work set so far back?
It has been perfect, I get very little spill on the hood and even less on the dash, all while lighting up the trail. I only use it for slow trail work at night... so it doesn't come on too often but when it does it is set up really nicely. Only down side is, when I open my sunroof it creates quite the whistle at freeway speeds but it isn't any louder at street speeds around town.
redthies
Renaissance Redneck
295/70-18 or 285/75-18 is a good compromise in a 34” tire that is a bit skinnier. It’s looking great with the Tundra wheels!
Rezarf <><
Well, I finally found the time to create, wire, and finish off my Dual Battery System with an entire auxiliary electrical system (breaker, fuse block, ground bus, relays and terminals). It wasn't too hard, but it took some time and planning. It came out nice and clean, and the Blue-Sea ML-ACR is the ticket to this kind of setup. In the end I wish I had gone a different route with the batteries as my Optima yellow top only has a surprising 45 amp hours... kinda lame.
img_3311-jpg.1675861
somebodyelse5
I'm building a really similar rack, using the gamiviti feet, do you happen to have the dimensions of the mounting plates with the slotted holes?
PNWav
