The ups and downs of searching for a lift kit
Carolina4x4
So real-world issues are bouncing around my efforts to find a lift kit for my 5th Gen 4Runner Limited. My ornery but highly skilled mechanic with 40 yrs experience working on Toyotas (all he does), poo-poos the basic lift kits (e.g., Bilstein 6112/5160) and wants to see me install at least an ICON Stage 2 ($2700 without labor) or similar (he is not brand obsessed). He says these better and more expensive systems greatly improve ride comfort, off road capability, and most, importantly, alignment potential and adjustability. In his typically brusque but compelling way, he writes:
[Better, more expensive systems] FIT RIGHT AND WILL LAST A LIFETIME WHEN YOU LIFT A VEHICLE YOU CHANGE THE GEOMETRY OF SEVERAL THINGS LIKE AXLE ANGLE ,SWAY BAR ANGLE, CENTER LINE OF DRIVE LINE , CASTER AND CAMBER ANGLES , CENTER OF GRAVITY , DRIVE SHAFT ANGLES , PINION ANGLES .
You need a system and an install that considers all these factors, he argues. But of course they are expensive, particularly when there are so many other things that need purchasing, skid plates, bumpers, etc. And they present the Overlander with added maintenance when on the road in remote countries and places if the suspension is fed by nitrogen and remote oil reservoirs. The ICON systems also come with a 30-50k maintenance intervals. So, is it just dumb for me to spring (!) for one of these systems?
The plan is to travel South America and eventually Africa. But in the next year or so, there will still be plenty of mall driving and work commuting with an unloaded vehicle...and some "dry run" off roading in the mts and hills of NC.
So I need guidance. Do I blow off the only Toyota-experienced builder in my area, who I believe will do a good install? Do I go with my Plan B, which is a lift kit from Bilstein or OME for around $1300 and get installed by the "mechanic down the road" who seems competent but has done only a lift kit on his personal truck and never on a Toyota? I don't have the tools, experience or space to do this job myself, so labor costs are a factor too. Here's the side by side:
PROS
ICON Stage 2: Tighter, better ride, more precise alignment
Basic Bilstein or OME:
DaveInDenver
Middle Income Semi-Redneck
I'm sorry to disagree with him, but you get a lot of bang for the buck with a 6112/5160 upgrade. Same with the OME options, you get real improvement and don't have to spend a bucket load of money.
Icon, it's a love or hate ride with the digressive valving. You really should ride in someone's truck with an Icon suspension before committing the money. Also quality is variable. But that's true of FOX (which I run on my Tacoma, they've been fine for me). IMO it seems most of the time King doesn't have quality issues but you pay for that dearly.
And honestly, I'm not sure 99% of us really need Icon/FOX/King. I had some extra funds when I bought mine and if I could get back I'd probably just have stopped with an OME system. Remember that with high end comes maintenance. You have to rebuild shocks periodically and if you use them like they should this is about every year or two at the most. You have to keep your old suspension to swap on if you don't have a second car (I don't). It's not the most convenient way to go.
Yeah, the ride is nice but I'm not sure it's worth it really. If you don't intend to stay on top of rebuilds, never change from stock valving and have never overheated shocks then I think Bilsten and OME are absolutely adequate.
Alignment, that is neither here nor there. If you want to make it easier to align after lifting you need upper control arms. I have Camburg with extra caster built in, which keeps steering from becoming twitchy.
For your intended use overseas I'd think finicky custom shocks would be a major disadvantage. Keep it simple and stick with what works, ARB and OME.
tacollie
Glamper
What he said! I've had icon, OME, Toytec Boss 2.0, and Bilstein 5100. The icons were nice but but my the boss 2.0 ride way better. I would rather spend my money on other things.
As far as the install it is super easy if the coilovers are assembled. Even if they need assembled it's not that bad. I can't believe what they charge for suspension installs!
Carolina4x4
DaveInDenver, this is why I post here. A level-headed bit of advice, and one to feel good about too -- more money over for other things! I will wait to see what others say, but you got me leaning in the right direction I think.
Ramjet
You can take your Coilovers to pep Boys and they will put them together for $50 for the pair. I had OME on my fj, Did over 100k miles on them and they never wavered. Plus it gave me the ability to save some cash. You can!!, do the install your self with some buddies and a few beers afterwards. It's not hard at all. You have friends right? Then they will want to help you out i'm sure. You don't need to spend $4000 dollars on suspension. People that do it, have money to spend and want to let everyone else know they have ICON on their ride. They aren't that big a deal. Cheers.
Carolina4x4
What do you guys think of this kit for my 2013 4Runner Limited? Looks like it is adjustable...I am looking for no more than 2" lift. Anything else I need to get for the install that is essential? I am thinking heavier coils on the back to compensate for trailer weight (app. 2500lbs).
TTBOSS-4R210 - ToyTec BOSS Suspension System for 10+ 4Runner
Your Price: $1,359.99
Carolina4x4
Way to go, ramjet. I'm on your page! But I don't have those friends...my friends only know how to talk ******** and keep their fingernails shiny....
thezentree
pretend redneck
I have the 3rd gen version of that with 550lb/in springs up front and really, really like the ride quality. I ran the non-adjustable Eibach shock/spring kit they offer for a few hundred miles before the BOSS system and got way more lift than I needed and it rode like crap. The BOSS system is pretty good bang-for-buck for a vehicle that's not going to see a lot of high speed offroad miles.
Disclaimer: my experience is limited to 3rd gen 4Runners. YMMV.
Ramjet
Well, Let me tell you. I have installed everything myself for the past ten years and I have zero mechanical experience. I just take lots of pictures and make sure I lay everything out as I take it off. Paint drop clothes work well for this also. You can also rent all of the tools you will need at AutoZone or any part store really. There are also a ton of threads on here with step by step pics. They really are fairly easy to do. Here's the one caveat i have also. You really don't need to lift your ride to be honest. I call it "Keeping Up with the Joneses" Syndrome. Your truck is perfectly capable of doing 75% of all trails in America and beyond. So if you dont really need to do it, dont. Cheers.
DaveInDenver
True dat. Now upgrading, different story. Even though I had TRD Bilsteins on my truck it rode terrible off highway. So putting aftermarket suspension on was worthwhile.
I'm using a medium-heavy spring pack with 7 leafs and I wanted them to not sit recurved but rather flat. This means the rear is about 2" over stock. So I have set my coil overs to match without having too much rake. But with the truck lifted my travel window is skewed so I have less down travel than up.
If I was driving a 4Runner I'd probably have kept the ride height lower and set the shocks to ride more close to the middle of window.
Dalko43
ICONs do not last, customer service is horrible, and digressive valving makes for a harsher ride (have had them for almost 2 years on my own truck). If you have to lift, get Kings or OME BP-51. That said, with your plans of traveling South America and Africa, I would leave the suspension stock (other than beefing up the rear to account for increased daily carrying weight) - it'll make finding new replacements a heck of a lot easier. (Good luck finding an ICON rebuild kit, proper oil, nitrogen, etc. in Africa.) In fact, I'd bring some spare OEM shocks with me on trip like that and not deal with any rebuilding at all. Much easier to just swap shocks.
^This.
Icon's and some other trending names may offer the performance, for a hefty price. But for remote travels on a budget, you're better off going with either a stock suspension or a very basic aftermarket kit (OME's basic nitrocharger shocks and complimentary springs are a prime example) with a proven track record and half-decent availability.
Honestly, the stock suspension on the 4runner rides fairly well, and it's very easy to make the ride worse by "upgrading" to a more costly aftermarket suspension. Only a few brands are really capable of making the ride and offroad handling better than stock. Icon, might be among those few, but I do think you're money is better spent elsewhere, especially if the 4runner is relatively new and unused.
Clutch
<---Pass
How long are you going to Africa for?
...and another question is, is it worth the hassle of shipping your vehicle there?
If it is short term, think I would just rent a kitted LC70 from one of those "Caravan for Hire" places over there, just to get the chance to drive one for a bit.
Goldenbora
