Small off road trailer, 5 gal water with sureflo pump, Optima yellow top, inverter, solar panel, LED lighting, Kenwood sound, much more, $3500
Commando Camper
furbucket
Do I see onboard air AND onboard BEER??
...sent from my an evil pocket calculator with a flashy screen...
Commando Camper
The quick disconnect is for the water hose, and that is a real working beer tap, a Co2 system is included, which could be on board air too. It holds a pony keg
Commando Camper
Other features include: Solar panel mounts to the inside of the lid when not in use, the inside, fenders and front of box and tounge are coated from Line X, not a rattle can, the lid locks are Caterpillar locks, the aluminum tube on the rear of the trailer pulls out then is flipped up for an aluminum table, and there is an aluminum table that mounts to the left side of the trailer to cook on, both store inside the trailer, there is a 5lb propane tank mounted inside that is plumbed to the outside for a stove, coffee maker and lantern, the tires are 35" pro comps on American Eagle wheels, 5 on 5 bolt pattern (Jeep JK)
V45W_Proto2.5
