2017 4x4 Sprinter Full Build - SOLD
freshlikesushi
Free Candy
I actually like this thing, but we decided after a dozen or so nights, we want a different layout. It is actually easier and faster for me to just do a full build again and how i want, instead of removing, replacing paneling with mount holes in it, then rebuilding everything in the layout i want. So, I'm just going to sell this one and redo it! Plus i want a different color.
100,000.00USD OBO
currently 4500 miles on it. Going to Tenn the 25-26 and arizona for expo west, so mileage as traveled.
Can be delivered at overland Expo West.
2017 Mercedes Sprinter 144" 4x4
Only things listed here will be included in sale
Exterior:
Aluminess Front Bumper
Warn 10S Platinum Synthetic line Wirelessly controlled winch
Lifeproof LED Rock LIghts
Knockoff ARB lights and Mount Brackets
285/75-16 BFG KO2
Fiamma F65s Awning
110 input port on passenger side
Maxxair Fan, manual open, mount adapter for sprinter
Flarespace Extended Flares, passenger side Window
Additional Sliding Door Stop Wedge
Aluminess rear bumper, tire swingout, deluxe box, shelf and top rail
ARB Single Air Compressor
Rear Bumper Air fill point
Air Horns
PA System
Rear facing led lights in rear bumper
Electrical
3 x 100w Renogy Panels Mounted on roof with Aluminum angle brackets to the factory roof rack rails
Solar gland on roof
8 ga wire to charger
Victron Connect 100/30 MPPT charger with bluetooth
Victron Connect BMV-712 Bluetooth battery monitor
2000Watt modified sine inverter
200AH AGM Battery
4ga going from builders terminal to rear
Blue Sea battery shutoff
CTEK DC to DC charger after shutoff to charge from builders port
Two switch panels (one in rear and front)
Both control lights and water pump, in addition to other front/rear needs
LED lights in ceiling
Multiple 12v and USB ports
Blue Sea fuse panel and components
110v, 30 Amp Marine grade 3 bank Battery Charger for charging from shore power (future battery additions)
6 switch integrated relay box for compressor/lights on exterior
Midland MXT115 GMRS radio
Majority of 12 gauge wiring used in vehicle for additions
Water system
25 gallon water tank on driver side over wheel well.
4 gallon Bosch 110v water heater running off inverter (with DC to DC charger and solar, not an issue)
All PEX fittings and lines throughout
Sureflow 3gpm water pump, strainer and accumulator
Rear door shower/sprayer quick connect/disconnect
Sink in trail kitchens unit with drain to 6 gallon water can
Water fill is internal to prevent ports in side of van
Interior
Rockford Punch Amplifier
Rockford Power Front Components
Rockford Rear 2 Ways
Shiplap interior paneling
Trail Kitchens Van Kitchen
Sound deadening in entire living area and doors
3m 2" Thinsulate in entire living area and doors
Rigid foam insulation in floor
Espar D2 heater under passenger seat
Seat Swivels
Lagun Table and butcher block top
Ikea Foam Full Size Bed
Fully custom built aluminum framed with wood inset structures to reduce weight.
Bed frame mounted on brackets to the wall from 1 x 3 aluminum
All cabinets, and underbed structures from 1" square aluminum
Flarespace flares were lined with foam them carpet for insulation and sound deadening
All doors and drawers have catches/latches to prevent opening while driving
All items are securely fastened to prevent movement during traveling or accidents
The only thing left for someone to do (if they cared) Is to finish the sliding door (current as is from the factory on the interior minus sound deadening and insulation that is done) and to trim out the very back (c pillar?) if they wish. Past that, this is a full functional and complete build that has been trail tested and wife approved.
However, dogs need a larger bed, since they require to sleep in ours for some reason. So we are going to literally get another Sprinter and just rebuild it. It will end up taking less time and wasting less parts doing it this way
Sprinter 4x4 by Grant Wilson, on Flickr
Untitled by Grant Wilson, on Flickr
darrylkd
