FS: Icon stg3 coilover susp for '15+ F150; NEW IN BOXES
mk216v
Der Chef der Fahrzeuge
I purchased this Icon Vehicle Dynamics stage3 suspension for my Magnetic '15 F150 FX4 late last year, thru Icon. I hadn't installed it then since winter was approaching and I was running Blizzak's on my stock 20s(which wouldn't look super cool with a lifted truck). Once late spring came I was going to get the Method wheels on 35's and install the susp. Plans changed and I'm selling the truck instead, so now this stg3 susp (still brand new in the sealed boxes) is up for sale. Your gain, my loss.
Icon stg3 susp new in boxes.
2015_up_ford_f150_4wd_0_25_suspension_system_stage3_2a837e9f915f45f9120738d30f7b898b5528aa53.jpg
Icon stg3 susp.
My truck currently with Blizzak's(winter mode).
KEY FEATURES:
• Adjustable front coilovers from 0-2.5" of lift height
• 2.5 Series rear piggyback reservoir shocks with 7/8" polished nitro steel shaft
• Tubular Upper Control Arms for added strength, durability, and alignment spec range
• 100% Bolt-on system - no drilling,cutting or welding necessary for install
• 6061 Aircraft grade aluminum CNC machined components
• Corrosion resistant CAD plated coilover shock body with 7/8 shaft
• High strength alloy CNC machined lower bar pin
• FK rod end bearings for extended longevity and minimal deflection
• Unique valving developed for the lighter weight of the 2015-UP F-150
• Vehicle specific tuned front and rear shocks for superior damping and vehicle control
• Increased wheel travel and ride quality over stock with no change in towing capacity
http://iconvehicledynamics.com/shop...d-f150-4wd-0-25-suspension-system-stage3.html
Retail from Icon is $3391.29.
Best new price you'll probably find is $3221.73 from Stage3 Motorsports.
$2767 firm + S&H to you.
LMK if you have any questions.
Goldenbora
